Lemmings - Game saves?
Discussion in 'Playstation Forums' started by winstano, Apr 22, 2007.
  1. winstano
    winstano
    Apr 4, 2007
    2,402
    63
    +213
    Every time I play Lemmings it says it uses an autosave feature to save your progress in the game...
    Yet every time I quit the game and start it up again, I've got to redo all of the levels! Does anyone else have this problem? It's immensely frustrating to get so far into the 'taxing' and 'mayhem' levels and then having to redo them all next time I play just because I quit when I was on level 10...
  2. Darth_terra
    Darth_terra
    Jan 13, 2006
    5,117
    UK
    +956
    That shouldn't happen the autosave should save the game, i have no problems it saves fine when i quit, it might be a problem with your copy try downloading and installing it again see if that fixes the problem.
  3. echelon
    echelon
    Apr 11, 2005
    176
    +6
    I have the same problem.
    you have to create a new profile under "profiles", then load that profile every time you start up the game.
    it doesn't seem to create a default profile - at least not for me.
  4. kingbal
    kingbal
    Nov 30, 2006
    1,320
    48
    +55
    yeh i had the same problem for a while. Should auto load on startup though:thumbsdow
