Legs on REL Stentor, Stadium and Storm
Discussion in 'Subwoofers' started by ReTrO, Jul 27, 2001.
  1. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    How long are the legs on the down-ward firing REL's?
    I am 're-packaging' my AE Aegis Sub and i'm going to make it look like the REL's, cos they look nice.
    Cheers!
  2. Guest
    Both my Storms (mk2+3) have 1.5 inch long (i measured) feet with a further 1.5 inch spike which will recess to about an inch when fully screwed in (should you be using on a carpet surface).
  3. Guest
    May dramatically alter the sub's performance if it is a forward firing design though.
  4. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    Cheers Steve.
    I was going to use 5cm (about 1.5 inch) feet with spikes anyway, so that's reassuring!
    Cheers again!
  5. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    If it does I can always pop it back into it's orginal box, and then i'll have a nice looking coffee table/foot stool!
