Left/Right AV Amp Volume Problems
Discussion in 'AV Receivers & Amplifiers' started by HOLOGRAM, Jul 1, 2001.
  1. HOLOGRAM
    HOLOGRAM
    I use a seperates system comprising
    Yamaha DSPe492
    Sony S725D DVD player
    Arcam Alpha 5 amp
    Mission Centre and Large floor Standing Missions Left/Right Main.
    I have recently noticed after looking into buying a new TV and hearing on oard Dolby Digita; systems that Im not getting a huge amount of volume from my Left/Right channels( especially in pro-logic ). I have the amp on half way up volume settings as advised in manual.
    This applies when when using it for Pro-Logic and Dolby Digital(processor in DVD player).
    Any help much appreciated - Thanks
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    That's IMHO perfectly normal, movie soundtracks have a very high dynamic range and hence need a higher volume level (as in position of the volume knob).
    If that's a problem activate the "night-mode" or set the dynamic range to MIN on the DVD player / AV amp (whichever is applicable).
  3. philmate
    philmate
    Nov 6, 2000
    217
    Southend-on-sea
    +4
    Not familiar with the Arcam, but if have it connected through it's aux connectors change them over to the "tape loop 1 in" connectors and go through the test tone sequence to re-set the balance.
    Hope this helps,
    Philmate.
  4. HeadBanger
    HeadBanger
    Sep 22, 2000
    2,216
    Ashingdon
    +478
    The Yamaha manual may well say set your L/R amp's volume to 12 o/c and would probably work fine with other Japanese amps. Japanese amps' volume contols tend to have massive amounts of gain - note how most have run out of steam even before the 12 o/c position has been passed!
    However, British amps tend to apply a more realistic amount of gain. his allows a far wider volume control range before the amp runs out of watts. So to acheive the same volume on your Arcam, you will probably have to turn the volume (gain) control up further (possibly to maximum).
    Finally - sorry to state the obvious but you really do need an SPL meter (from somewhere like Tandy) in order to set the speakers at the same output level.
    Hope this helps. :)
