Led's with normal dimmers?
Discussion in 'Smart Home, Climate Control & Security Forum' started by worz, Nov 8, 2017.
  1. worz
    worz
    Oct 20, 2005
    485
    +49
    I currently have a varilight dimmer switch with 4 gu10's.
    Can I swap for LED GU10's?
  2. BirksyR
    BirksyR
    Nov 23, 2009
    155
    Liverpool
    +6
    Yes, but they will have to be ‘dimmable’ - it’ll say on the packaging.
  3. BirksyR
    BirksyR
    Nov 23, 2009
    155
    Liverpool
    +6
  4. worz
    worz
    Oct 20, 2005
    485
    +49
    Yes that's the sort of thing, I was worried as I started reading about LED dimmable switches, making me think there is a difference.
  5. Borospark
    Borospark
    Jan 8, 2014
    3
    There is a difference, depending on your switch.
    LED lights need a dimmer that works on the trailing edge of the waveform, not the leading edge.
    Check here for compatibility
    VARILIGHT Dimmer Switch Compatibility Guide
  6. neilball
    neilball
    Jan 7, 2005
    2,932
    Scottish Borders
    +648
    Or choose a lamp that is compatible with both types, such as the Megaman universal dim range.
  7. Cliff
    Cliff
    Mar 17, 2001
    6,708
    167
    Kent Accra Rub Al Khali
    +4,212
    Even if you get a trailing edge dimmer, and dimmable LEDs, they might not dim fully. You can also get flickering.
    As mentioned above, Varilight make some programmable dimmers, where you can set the dimming range.
  8. worz
    worz
    Oct 20, 2005
    485
    +49
    Thanks Guys, I wasn't looking at spending too much as i expect to move house in a few months. The megaman and new dimmers are a little expensive.
