thanks ive got a headache now! im after a 40 to 42" tv to watch and occasionally play wii games my budget is 500 quid dont really want plasma any reccomendations pleaseRead this first - will take a while
http://www.avforums.com/forums/lcd-...about-fantastic-radically-new-technology.html
What size TV do you want and what will you use it for?
firstly, i am new to forum so hello to all, led tv is this the future and should i buy one instead of lcd? i know led is sort of lcd but backlit, what are the pros and cons of both, thanks.
as above watching sky not hd got the box but not the subscription and a few wii gamesWhats the set going to be used for?
why would plasma be your first choice?If you do not have any reflection issues in the room you will site the TV, then as vickster suggests, Plasma would be my first choice, or if you are sold on LCD/LED, the Samsung UE40D5520 has great reviews in your price range, but also has a high gloss screen... The Panasonic 30B series have matt screens, also around your price range.
Alan.
hi found 1 for £428 but no warranty will try and find 1 locally to have a look at anybody else with any ideas/ taOne in the price range I was seriously considering was the PANASONIC VIERA TX-P42S30B 42"... presently £499-00 at JL with 5 year warranty... http://www.johnlewis.com/231263085/Product.aspx
Check reviews before commiting yourself.
Alan.
do i need 3d ?For £50 more you can get 3D functionality with the 42ST30 from JL - better filter, panel
made my mind up going for lcd 42" any ideas? also notice most ive looked at only seem to have 1 scart connection i would have to use adapter for multiple scarts
