LED Tape wiring diagram with Rako (HELP)
Discussion in 'Home Cinema Buying & Building' started by rob8510, Jun 10, 2015.
  1. rob8510
    rob8510
    May 4, 2015
    4
    Uk
    Hi All
    My first post, so please be gentle.:D
    I've read lots of post be would appreciate an experienced guy or girl looking over my drawing.
    I'm planning a lounge re-model and I'm looking to upgrade the lighting system to RAKO (wireless)with four scenes.
    I have a question on the LED lighting around the dropped tray ceiling.
    The total length of the LED tape run is 17m which I plan to split into two loads.
    I think the drawing is correct but any advice is very welcome.
    Rob
  2. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,525
    Kent
    +830
    Is the diagram suggesting you are wiring to the LED tape and also around the first LED tape to the second?? Or is that just a label??? Other than that looks fine. Well except where you switched red and black between positive and negative
    You identify the two Rako units to the same channel number to group them easily.
