LED tape lights stopped working..
Discussion in 'Home Cinema Buying & Building' started by sonicsnail, Sep 9, 2012.
  1. sonicsnail
    sonicsnail
    Jan 28, 2008
    26
    Hi all,
    In our recent kitchen renovation, we had a 5m RGB 5050 strip installed. It was a first for the electrician who did cut it into 3 and joined the three strips in under 3 units.
    However, one of the three has stopped working. Doesn't light up at all. The other 2 sections are working OK.
    The sparky soldered all the connections.
    So, onto troubleshooting..
    Are these strips VERY unlikely to fail, thus I should be looking at the soldering? Or is a failed strip fairly likely so I should make replacing that strip my first port of call?
    Thanks,
    Pete
  2. supraTTman
    supraTTman
    Feb 1, 2011
    1,007
    Portsmouth, Hampshire, UK
    +166
    If the strip doesn't display any colours at all then it is almost certainly a bad connection on the V+ line. Usually, the V+ wire is either black or white. You could also try connecting a wire between V+ at one end of the strip and V+ at the other end. LED strips can be fed from either end or both ends to reduce dimming at the non-connected end. This is called dual feeding - a bit like your ring mains.
  3. sonicsnail
    sonicsnail
    Jan 28, 2008
    26
    I opened up the soldered and taped end of the broken strip and alas flicker flicker they went. Tidy connection reestablished and lights now working again!
    Thanks..
    Pete
