n10enthusiast
Hi, I hope you can give some advice. My requirements is to replace the current very bright white Teucer led strip lights in my hallway, with very warm amber led strip lights. The hallway is about 7m in total length but is split into two sections of about 3.5m each, and currently connected with two Teucer dimmable led 60w drivers. These are both connected to a recessed PIR sensor in the ceiling, so that when I walk in the hallway, they come on but it is too bright.
I am therefore thinking to buy RGBW led strip lights, so that I can make the colour very low and a warm amber light.
I have looked at the hiline-lighting.co.uk website and am thinking of the following but will this work, or is there a better setup? Anything else I would need to buy?
2x RGBW LED Strip (RGB+WW) 5m roll | 7.2W/m | 24V | IP00 | quad LED chip
1x RGB + Tunable White 4 Zone | Combi ZigBee Remote Control
2x ZigBee RGB+Tunable White LED strip Controller 5 channels (4 in 1)
2x LED Driver | 24V | 30W | IP67 | Constant Voltage | EC Series
Thanks for any advice.
