LED question
Discussion in 'Home Cinema Building DIY' started by Darren Blake, Oct 7, 2003.
  1. Darren Blake
    Darren Blake
    Apr 28, 2003
    625
    Norwich, UK.
    +15
    Not really AV, but here goes anyway...
    I want to squeeze as much brightness out of an LED as I can. The LED I have chosen has its nominal brightness (5cd) quoted at 20mA, but has a maximum forward current (If) rating of 50mA.
    My question is this: Is the max If figure for a constant current or only for a short time? How would the life of the LED be affected if I ran it constantly at, say, 75% of its max If value?
    TIA,
  2. The Hemulen
    The Hemulen
    Dec 5, 2002
    549
    Cambridge, UK
    +19
    As far as I know the max If rating should be continuous. LED's will take a good deal more pulsed but I wouldn't imagine this was a pulse rating being quoted.
    Keep to a single limiting resistor per led to be safe if running them hard.
    By the way, I'm not sure you'll get 50% more perceived brightness running them 50% higher current.
    I'd give it a go and see what happens. Led's are fairly cheap after all...
