LED lighting & acrylic sheets
Discussion in 'Home Cinema Buying & Building' started by Daverey2, Jan 25, 2008.
  1. Daverey2
    Daverey2
    Nov 12, 2004
    155
    Cheshire
    +18
    Hi All
    I'm currently running through some ideas of how to create some cool lighting effects around all my AV equipment.
    One idea I've had is to stand each component (TV, Receiver, Sky+, DVD, speakers etc) on a cut-to-size sheet of 10mm clear acrylic, and then attach an LED strip (like the Apollo kits advertised on the forums) to the back of each acrylic sheet. The effect I'm after is for the light to shine through the acrylic and make the sheet edge light up, but not too brightly as to distract.
    Has anyone tried this or does anyone know if it would work out OK??
    I've seen online suppliers of acrylic sheets (such as http://www.westwardplastics.co.uk/d_selector.php?cat=glazing&subcat1=Clear Acrylic%&subcat2=Thick) - can anyone forsee any problems with this?
    Alternatively, does anyone have any other cheap-ish, easy to install lighting effect ideas I could "borrow"?
    Thanks in advance
    Dave
  2. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
    Think that should work, although there may be better led products (LED ribbon / strip?) - the apollo product is designed within a tube with a view to diffusing the light whereas your idea would probable want a more "directed" light source?
  3. Fieldling86
    Fieldling86
    Jan 3, 2008
    61
    +4
    Another way would be to drill shallow holes in the back edge of the acrylic and inser LED's of your choice. This way the light will pass through the sheet rather than over it and I think it will give a stronger/better quality light on the front and side edges.
    I have been told that one issue with acrylic though is that if you have a hot running AV amp/receiver or hot equipment, it can warp or become uneven!
    Hope this helps?
    Per
  4. Daverey2
    Daverey2
    Nov 12, 2004
    155
    Cheshire
    +18
    Thanks for the suggestions guys.
    As for the point above, do you know of anything that might work instead of the Apollo lights??
    I like the ideo of drilling the acrylic and putting in LEDS, but I'm no DIY man, and certainly no electrician, so that might be a little way out of my league!!
    Dave
  5. Oily
    Oily
    Jun 11, 2007
    1,062
    Radcliffe
    +83
  6. Daverey2
    Daverey2
    Nov 12, 2004
    155
    Cheshire
    +18
    Do you have a link for where you bought the acryllic from? I'm quite interested in doing something like your setup - although I think I might end up getting a wooden cabinet made and just using the acryllic under teh equipment to give some sort of light out?
    Ta
    dave
