LED Lamp and Fibaro Dimmer?
Desmo
Hi all,
I've recently got a couple of bedside lamps with dimmable LED bulbs. I'd like to add these in to our system but there's not much room for a plugin dimmer module so was wondering if I could use the Fibaro Dimmer modules?
I have these in our ceiling lights but not sure if I could use them with a lamp.
The lamps just have the normal two wire cable with an inline switch. I'm guessing I can just wire the module in between the plug and switch. I'm guessing I'll also need the bypass in there as well.
D
Deleted member 24354
Why not just add a couple of Hue lightbulbs instead? Would be far easier.
Seb Briggs
Or Zwave bulbs if you didn’t want hue but yes the Fibaro dimmers would work fine as you suggest with bypass
Desmo
The lamps have a very unique looking led bulb in them...the bulb IS the feature so not going to swap it out for anything else.
Seb Briggs
You could also use the cheaper Shelly Dimmer Wifi module if your hub supports Wifi or you dont mind just using their app or just Alexa/Google.
As you will neutral for the dimmer you shouldnt need their bypass
D
... or just buy some smart bulbs. They come in all flavours of Wifi (Lifx), Zigbee (Hue) and Zwave (Aeotec). Far easier than re-wiring your lights.
We just use Hue bulbs for bedside lights. I have an Echo Dot by my bed and the wife has a Hue stick-up switch.
Seb Briggs
I think the issue is that the lamps have specific LED bulbs with a distinct look, that they wont get with smart bulbs
D
Sorry I missed that. My bad. OP you may need to check then whether the bulbs are leading edge or trailing edge dimming and that the dimmers that you use are compatible. Trailing edge are normally best for LED bulbs
Desmo
Cheers guys. I'll see if I can get more specs on the bulbs.
I think I'll go with the Fibaro dimmers as they're super reliable in the rest of my system. I just wanted to check that I wasn't missing anything obvious or about to do something daft :)
Seb Briggs
What hub/system do you have ?
I would however give the Shelly Dimmer a go at £20, i cant speak highly enough of them and i'm also usually a big advocate of Fibaro. The shelly dimmer only needs a 10W load as well compared to the Fibaro 30-50W
Desmo
I use a Fibaro HC2
Seb Briggs
Ok, I have a virtual device for the Shelly Dimmer for HC2
