Hello
I am after some advice on LED downlights for an open plan area in a barn conversion, after much deliberation I had largely decided to go with Low Voltage 35W Halogen but in an effort to reduce running cost and be a little greener I am considering LED's. I think they are the way of the future but are they there yet?
The area is approximately 12m x 5m with a ceiling height of about 2.2m, it will have a total of 36 downlights. The lighting is split into seven circuits, each having 4 or 6 downlights, I plan to use the Clipsal Ulti wireles range of switches to control it all and set scenes throughout. Oh and just to make it more difficult they need to be dimmable.
I have struggled to find a lighting shop or electrician in the area with sufficient knowledge of LED's and so I would be grateful for any advice and experiences that people have had using LED's as main lighting and for advice on the best fittings to use and their type as I am now totally confused as to how they should be fitted and powered, (LV fittings and use or bin the included transformer?, LV fittings without a transformer and use a transformer for each circuit? etc, etc)
So far I have found the following that potentially could be suitable:
Dimmable Only - by Ultra Leds U.K
EcoLEDLighting :: EcoLEDLighting Dimmable LED Luminaire
DiamondLED Respondalight Systems
MR16 LED Spotlights - LedEcoLights, the LED Eco Lighting & low energy lightbulb specialists
Thank you in advance for your advice, comments, sugestions.
