LED Bulbs
Polly55
I tried to remove an LED bulb which is in good condition and cost £10, and the glass covering the bulb came off. Can anyone tell me if it is safe to use without the glass ?
simonlewis
Pictures might be usefull.
Polly55
Polly55
Hi Simon, the third picture is the glass that came off with the rubber suction tool I was using. I hope the picture help.
NorvernRob
It shouldn't be an issue at all, I have several of the small screw in type with the same SMD LED's and they don't have any glass covering. I've seen some like yours with glass and some without so I wouldn't worry.
John
so long as you don't put your fingers anywhere near the SMDs you should be fine. Until it goes properly
Sonic67
Drop of superglue at the edge?
IronGiant
I would, because the exposed solder joints often carry mains voltage :)
MrSossidge
Who in their right mind would want to touch them anyway. You know, just in case.
Sonic67
You want to remove the bulb as you think it's blown. It's protected by a two way or intermediate switch so not obvious if the switch is isolating the fitting or not. You stick your fingers in to remove the light from the fitting, you think the switch is off, some of the solder carries mains voltage. Let's hope you don't have a split load board where the lighting circuit isn't protected and you do have a good RCD. Also bear in mind it might not be you changing the bulb.
No idea if that lots credible, but as we used to say, "lick your fingers, have a go, and let us know how you got on."
Wahreo
Just replace it.
It's a five quid lamp.
If you want to bodge it then stick the plunger on to the glass, whack some super glue on and then stick it back on.
DevCode
Be careful, some led bulbs have live voltage on the pcb especially cheaper versions, isolate the circuit, remove and dispose of the bulb.
IronGiant
Another point to bear in mind is that if the bulb has a protective glass screen, there is no reason why the pcb shouldn't have live mains electricity on the surface of it, because your'e not supposed to be able to touch it. If you accidentally pulled the back off a mainsplug, exposing the wiring you would be very careful how you unplugged it, this is no different.
See those black and red wires? One of them is very likely carrying 230-240V mains power :)
No, it is not safe to continue to use it.
img_20160111_185219-jpg.666746
NorvernRob
Am I wrongly assuming that it's 12 volt? If so ignore my post OP, sorry for the rubbish advice! I have 12 volt LED's both with and without glass covers.
IronGiant
They are almost certainly GU10 bulbs that run on mains voltage. But it's a good point, if they are 12V it's probably fine. @Polly55 are they mains (GU10) or 12V with a transformer (most likely MR16 bulbs)?
NorvernRob
I may be wrong here, but don't GU10 bulbs have a built in transformer to lower the voltage?
IronGiant
Yes, but due to brilliant design mains (or a potentially lethal) voltage is often present on the face of the pcb. It's something I was unaware of until there was a thread about it in here. I tested some open faced GU10 bulbs I had installed in the kitchen with a multimeter and binned them. I only buy covered ones now.
NorvernRob
Wow that's pretty poor, my ceiling lights are all MR16 but it's handy to know!
John
I looked for that thread last night. Pretty sure @Stuart Wright posted vids in it. But couldn't find it
Latest News
What's new on Netflix UK for November 2021
  • By Andy Bassett
  • Published
PrimaLuna debuts Evo 300 Hybrid integrated amplifier
  • By Andy Bassett
  • Published
Astell&Kern announces AK ZERO1 in ear monitor
  • By Andy Bassett
  • Published
McIntosh launches MI1250 power amplifier
  • By Andy Bassett
  • Published
AVForums Podcast: 13th October 2021
  • By Phil Hinton
  • Published
