LED 5050 from existing ceiling rose
Tomdw82
1st post here, although long time lurker.
I have a set of 10m 5050 LED strip lights. They are run from a 6a psu, with kettle lead style plug.
I want to be able to run these from the main light switch, and remove the existing light fitting. Is it as simple as cutting the plug off and connecting the live, neutral and earth up to the wires in the ceiling rose (although I will remove this and replace with a connector block)?
Or do I need to fit a fused switch between them?
Thanks!!
Tom
