Leaving your AV32R on in standby?
Discussion in 'TAG McLaren Audio Owners' Forum' started by P Adams, Nov 10, 2003.
  1. P Adams
    P Adams
    Nov 1, 2001
    224
    Hampshire
    +20
    Do any of you leave your AV32Rs on in standby all the time?!!!
    I was told by Russ Andrews after purchasing some of his mains cables that it was a good idea to do this with my TAG as well as a Rotel 1075 power amp. My Toshiba 900 DVD player is always in standby so I don't have a choice
    Better sound and less strain on components at start-up so they say
    I am open to opinions!
    Paul
  2. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    Yes!....not sure if it makes any difference to sound quality as it's always been left that way,but certainly it can do with some items like some power amps and DAC's.
    In my system it's just used for convenience.
  3. mark67
    mark67
    I just turn the display OFF and select an unused Input. I don't think I ever turned off or put into stand-by, any of my Pre/Power Amps or CD Players.
  4. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    In my case the power amps have to be turned off or the electricity bill would be excessive!.....I do leave the Upsampler and other digital gear on though.
  5. cskates
    cskates
    Jul 5, 2001
    151
    Belfast, UK
    Mark> No need to do that, standby on the AV32R is essentially the same as muting. Most (all?) of the circuitry remains active to keep it warmed up.
    Only time my AV32R gets turned off is to reboot for an upgrade :)
  6. scarty16
    scarty16
    Jul 1, 2003
    1,046
    +94
    In the AV32R manual it says something like 30w when in use and 25w when in stand by, so what if anything is even turned off?
    Not sure about the amp though.
    But then again I turn it all off all the time, saves money on the old electricity bill!!
  7. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    I think that as cskates said,most of the circuitry is left on,but the display is powered down,so that may be the main difference.
    As for the amps,I'd love to leave mine on,as they always take at least 30 mins to reach their operating temp,and sound best then...but,as you say,electricity bills can play a part.....most Class A/B amps will have no problems,but Class A amps draw large amounts....
