Leaving Power amp on
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by Stereo Steve, May 24, 2004.
  1. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    I should be taking delivery of my 1205a soon and although it has a trigger input (I think), I may be changing my amp to one which doesn't have a control output.
    Reading some stuff that I got with some Russ Andrews mains stuff I bought, he says to leave all your equipment on 24/7 which is something I have never done. I do leave my sub on all the time and that seems OK. So, if I leavethe 1205a on all the time, will it get hot and use a lot of electricity or will it sit there as cool as a cucumber until it is required to rock and roll?
    Anyone leave their's on 24/7?
  2. vizslaraner
    vizslaraner
    Dec 13, 2003
    487
    Hereford
    Nope. The only item left on is the Quattro; the 559, sub and Pace are left in standby; the remainder is turned off.
    N.B.
    Used to leave the Pace on, but in doing so it had the annoying habit of locking up from time to time. Leaving it in standby has solved this minor irritation.
  3. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    Steve
    I tend to leave my P7 on all the time, find its got "more" to it
    John
  4. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    Does it get hot, or just warm up when used?
  5. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    I leave my powers and subwoofers on 7/24, so far no problem... :rolleyes:
  6. mick23
    mick23
    Mar 20, 2002
    801
    uk
    sterio steve
    when i chatted to henry at crt projectors re the a23 halo about the signal sensing auto turn on etc, i was advised to just power up the amp say half hour before using ,and turn off at night.
  7. lovegroova
    lovegroova
    Jul 15, 2002
    2,730
    103
    Herts
    +388
    I used to leave my Rotel RMB1095 on all the time as its consumption wasn't huge. However, the Krell I now have uses 235 watts at idle, so I use the 12v trigger to switch it on and off. The manual states that 10 mins warm up is sufficient.
  8. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    Just tried my 1075 with no signal and it does get warm which means it's using a bit of electricity. Adds to the heating in the winter I spose. I'll have to see how much the 1205 uses.
  9. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    Mine is barely warm if left on 24/7, but the sonic benefits are, to my ears worth it
  10. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    Mine are a set of the old KMA's and use as much idling as they do at full tilt,so it amounts to in excess of 500W per channel and more under full drive,so when they're not being used,they stay off!....like all Class A stuff they take a good 30mins to get up to temperature.
    Tha Parasound is a good bit more efficient,so it shouldn't be too much of a problem to leave it on.
  11. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Most amps draw a small current even when they receive no signal and hence produce some amount of heat. I would switch my kit of for saftey reasons, in particular for longer periods of time (at night or when I am out of the house, holiday etc.).
  12. Peter Baker
    Peter Baker
    Sep 6, 2003
    656
    28
    LONDON
    +37
    No way I can leave the Proceed AMP5 on, it's like a radiator!!
    I do leave the pre on standby howerver, with no apparent issues.
    The power amp definitely sounds better after a 30 min warm-up
    Regards
    Peter
  13. mjn
    mjn
    May 24, 2001
    22,443
    Herts, England
    +10,482
    always leave my rotel 1075 on 24/7
  14. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    Just set up my 1205a and have left it on for a couple hours with no input. It gets warm but not really hot. No hotter than my Grundig Sky box anyway. One thing I did notice is the improvement in sound as it warmed up, quite dramatic. I think I'll leave it on and see how hot the cabinet gets. Trouble is, my kit will soon be enclosed and I planned to have the doors open when in use and closed when not. It will be a big cabinet though with loads of space around and above each component.
    The main problem is I have decided to go from a Denon 3803 to a Marantz 6200 for processing duties (until I can afford another AV32R) and it has no trigger output.
  15. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Get a Master-Slave AC outlet (socket) then!
  16. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    Eh what? What's that and where can I get one?
  17. General Skanky
    General Skanky
    Jul 28, 2000
    4,251
    71
    Colchester
    +44
    I used to leave REL subs on the whole time. Also my old Densen Beat amp was 'never' turned off! The audio difference from cold to nicely warm was dramatic.
  18. General Skanky
    General Skanky
    Jul 28, 2000
    4,251
    71
    Colchester
    +44
    But having said that, I now have active ATC speakers which I turn on about 30 mins before use otherwise they can sound a bit clinical until 'under steam'.
    I haven't left them on for any length of time when not in use.
  19. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    See here
    Should be available in electronic (component) stores or handy marts.
  20. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    Thanks guys. I have just bought a Marantz 7200 to replace my 6200 and that has 12v trigger outs, so problem solved. I think I'll probably fire the receiver up in the morning and turn it off at night if I remember.
    The 1205a definately needs to be warm before it sings.
  21. Black 5
    Black 5
    Jul 19, 2000
    367
    19
    Isle of Man
    +3
    All my audio stuff is left on standby. The power amps do get warm, but as most electronic components fail when being switched on from cold rather than when warm, I'd rather live with the small cost. Answer might be different if I had Krells! I used to own Audiolab amps and they were all class A design, but left them on anyway. Though there's heat being generated, I'm not sure they would consume the equivalent of their actual power ratings when idle, ie 200w.
  22. wolf
    wolf
    Why do anyone bother turning off the water tape? Water is cheaper then electricity is it not?
    Do you ever turn off your lights at night before going to sleep? A few light bulbs only uses the same amount of energy as your toys on idle. So why doing one but not both.
    On more thing. Which do you think of these use more energy, one 2000W electric heater in one hour or
    an stereo amp leave on idle for 4 days? :rolleyes:
  23. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    But cleaning up the mess left by flooding can get prety expensive... :rolleyes:
  24. wolf
    wolf
    Lowrider,
    I am sorry for coming across as making a mountain over a very small issue.
    When I first read those Russ Andrews promotional magazine that they sent out my first impression was it makes interesting reading. Free upgrade to sound quality for very little money etc..
    If you read it again but with a more critical eye they are actually no better then one of those many audio-guru promoting pseudoscience to gullible fan who are actually keen hobbist. They are just not true. Keeping your amp toastly don't actually takes that long.
    In this case it also promote a thinking that natural resources is something that comes out from thin air. Just because we cannot see electricity like water or know how it is produce it seems many people don't actually make the connection that like any other form of energy it is not free.
    If all of us are so wastefull the power have to be manufactured from some way some how. We are actually asking for more nuclear powerstations to be built or petrolium reserve to be burn up faster. Or more polution...Nothing comes free.
    I know it is a bit difficult to make the connection from not turning off your hifi to world energy resources. Think about it a bit. Peace.
    Wolfgang.
  25. karkus30
    karkus30
    Jul 29, 2002
    13,997
    +1,236
    How do you answer that post ? Im guilty for leaving my system powered up :blush: but it sounds so much better, Naim pre amps take days to warm up, its not a arbitary statement, its all down to capacitor charging.
    Would I change........in a word, no............but Im mindful of the extra energy expenditure (the cost is not an issue). Solar cells ? might be a way forward, theres some interesting developments on that front.
  26. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    Dont worry, I got a digital amplifier because it uses a lot less power, particullarly when I leave it on, also I decided against a plasma because it uses too much power, will go for LCD or DLP retro instead... :rolleyes:
    Actually what I just said is true, but I am more worried with having enough juice for all the kit... ;)
  27. wolf
    wolf
    In my humble opinion those are actually very sensible idea. We should be more supportive of alternative reusable energy resources and at the same time make use of more energy efficient solution. Hmmm.... there must be a way to enjoy spining these discs without any guilt. I turn off my toys, including a 500W amp, because I never find then that much audible differences after a few minutes. Let your ears guide you.
    If those digital amp have such a sonic benefit we are on to a winner on both account.
    Btw personelly I find those wind farm turbines actually quite beautiful and serene to look at. I am not an engineer but they look like they odd to be more efficient then those old crumbly wooden windmill that everyone seems to be very keen on.
  28. Dellboy
    Dellboy
    Apr 24, 2002
    606
    43
    The Cotswolds
    +135
    I'm with Karkus 30. I always leave my Naim equipment on. If they are left off and cold for more than a couple of hours they do take a considerable time to get back to their optimum state of perfomance.
    I've always been told to keep the pre amps and amplifiers on if you need a consistant level of perfomance.
  29. wolf
    wolf
    Many people tell me a lot of things too but over the years in this hobby I find one need to choice who to believe and above all follow my ears and learn to listen carefully what really makes real differences.
    Thanks for helping to confirm my next choice of amp will definately not be a Naim. Maybe it does sound good after a week later. There are many others that sound excellent within a few minutes. :rolleyes: Hifi is suppose to be toys to enjoy. Peace.
  30. mjn
    mjn
    May 24, 2001
    22,443
    Herts, England
    +10,482
    let them build more nuclear power stations.....
