Leaving a space between LCD and canton cd10 front speakers
Discussion in 'Home Cinema Speakers' started by martind, Sep 9, 2005.
  1. martind
    martind
    Jul 29, 2005
    1,212
    38
    Birmingham
    +20
    In the brochure that came with my Canton CD1 speakers, it says to position the cd10 front speakers 30cm from the edge of the tv screen.
    My problem is that my LCD is wall mounted and all cabling is hidden, so if i do as canton say there will be visable speaker wire between the CD10 and LCD. Resulting in grief from the wife. Can i just ignore what Canton say and position the front speaker flush to the sides of the LCD??
  2. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    yes, but panning effects won't be as good. you could have them a lot further apart, say in corners?
  3. pragmatic
    pragmatic
    Nov 9, 2004
    12,150
    +1,647
    Its probably to do with them noit being magneticaly shielded, LCD's are immune to this were as CRT can have all sort od strange distortion when a dtrong magnet is near.
    I'm not sure if plasma's can be effected in this way by the magent of the speaker, i suspect not though.
    Anyway if your using an LCD then you don't need to worry.
    As for better sound stage and 3d seperation then it would be ideal if they were further a part but if you can't.
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,379
    Somewhere in South Yorkshire
    +5,765
    Only CRTs (including CRT RP, although effect is a different one) are affected by external magnetism. All others aren't.
  5. AMc
    AMc
    Nov 20, 2000
    6,827
    Near Norwich
    +3,402
    And the CD10s are sheilded. I've had conflicting advice about this - first one, speakers should be in an equal triangle with the main listening position. Second one, The left and right should be next to the sides of the screen to mirror the action. In a cinema all front 3 speakers (cough) are behind the screen.
    I would put them next to the screen if that's going to save you a lot of trouble.
    If you hate it then try chasing the wall and putting the cable in it, but that sounds like a lot of trouble for not much gain.
  6. Troon
    Troon
    Apr 28, 2005
    151
    That's only conflicting if you have a small screen... ;)
