learning ir codes
Discussion in 'Home Cinema Control & Remote Controls' started by sirata, Dec 4, 2003.
  1. sirata
    sirata
    Jun 14, 2003
    296
    28
    GUERNSEY
    +53
    I have bought an axim x3 and wish to use as a remote .
    i have got pdawin and have loaded a ccf from remote central.
    to get used to it before i do my own ccf i am trying to asign
    the icons to my sky remote.
    But i am stuck at the first hurdle.
    i have tried to assign an icon to sky movies(channel 301 )
    so i have gone to
    LEARN
    TAPPED ON THE SKIN BUTTON
    TRIED TO TYPE IN 301 ON MY SKY REMOTE
    But as soon as i type 3 it seems to assign just"3" to the button
    how do i get it "too wait for the 01"
    I can see how you assign 1 for 1 but not when you need 2 or 3 different keys on the original remote.
    Any help appreciated.
    David
  2. Sandman
    Sandman
    Nov 28, 2002
    3,608
    Glasgow
    +1,341
    You need to learn the number keys to 10 different buttons on the axim. i.e. create a keypad on the axim. Now to asssign a button to take you to channel 301 (sky movies) you need to create a button that will do the following:
    keypad 3
    delay 0.1s
    keypad 0
    delay 0.1s
    keypad 1
    This is the only way this can be done with any learning remote (it is called a macro).
  3. sirata
    sirata
    Jun 14, 2003
    296
    28
    GUERNSEY
    +53
    Thanks very much Sandman
