Learning and IR code remote?
Discussion in 'Home Cinema Control & Remote Controls' started by jgrg, Jan 10, 2005.
  1. jgrg
    jgrg
    Oct 19, 2004
    547
    28
    Cambridge
    +33
    I have noticed that the manuals for some pieces of equipment come with a table of IR codes. For my Arcam CD player these include commands that are not present on the supplied remote control.
    Does anyone make a remote control that I could program directly by entering the numeric IR code, as well as by learning? (Or maybe one that you can set up from a PC that has a large database of equipment would achieve the same result.)
    James
  2. mambojambo
    mambojambo
    Dec 23, 2004
    141
    +3
    yes any of the pronto remotes offer all those features and a database is available on remote central
  3. Ikki
    Ikki
    Feb 23, 2004
    1,173
    2
    67
    Lancs
    +97
    You can do this for the Harmony remotes as well.
  4. GreenBars
    GreenBars
    Oct 29, 2004
    631
    Hertfordshire
    +23
    Kameleon 6 too.
