guido
Established Member
Just finished installing the Leadtek WinFast DTV1000 T DVB-T card in my Media Centre PC and all seems good so far!
Bought from eBuyer for only £36 inc. VAT - Bargain if you ask me! Comes with own software and remote so don't actually need MCE.
Very easy to install with my HTPC running with MCE2005 Rollup2. Ignored instructions to cancel hardware found wizard and run own install from CD as I didn't want to install all the software that came with it. So just copied XP Drivers directory onto PC, then let the New Hardware Found wizard run, but limited search for drivers to directory copied onto PC. Popped up new Hardware Found about 4 times for encoder, tuner, crossbar and something else can't remember! and that was it. Installed!
Then went to Setup TV, and quickly set up no problems. First scan picked up 65 channels (from Crystal Palace Tx).. took about 3 minutes. Haven't downloaded guide as currently not on the internet.
TV picture seems fine, but hard to tell as just watching on old 15" CRT as still waiting for new graphics card to arrive with S-Video out... so still using intel 62865G built in graphics. Until get new graphics card and hook up to TV won't be able to do comparison with existing freeview set-top box. Changes channel almost instantly.
Tried a quick record and seems pretty good too. Will let you know how the guide works when on HTPC connected to the internet.
Also plugged in Microsoft MCE Remote control for first time tonight. Works a treat too - recommended - £22 from eBuyer.
All in all for £36 seems great value for money.
