Lead check, 79/300
Discussion in 'Hi-Fi Stereo Systems & Separates' started by johnr2110, Jan 2, 2007.
Tags:
  1. johnr2110
    johnr2110
    Aug 26, 2006
    2,754
    2
    2
    68
    Eastbourne
    +94
    I'm soon to take delivery of a DV79 & a AV300, which I intend to connect to a Sky HD box & a Plasma TV. As this is a system upgrade the speaker cables are fine I also have a coaxical cable running between my current amp & dvd
    so ok there " I hope".
    I've also got a descent HDMI lead to run between the TV & DVD, will use the Sky supplied one for the HD for a while .
    Also I believe I will need an optical cable between the amp & HD box.
    Is there anything I've missed?
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,577
    Edinburgh
    +1,269
    For playing CDs I would recommend connecting the analogue outputs on the player to the AVR300. If you want to play DVD-Audio also you will need 3 pairs of analogue cables, if you plan on only playing CDs then you will just need one pair.
    You may also want to have to hand a basic phono to phono cable for getting the onscreen menu from the AVR300 on the TV whilst setting it up. You can remove this cable afterwards.
  3. johnr2110
    johnr2110
    Aug 26, 2006
    2,754
    2
    2
    68
    Eastbourne
    +94
    Thanks crustyloafer I'm having the system proffessionally installed, I'll contact them about analogue leads.
