P
Pgamer
Guys,
Anybody found good settings for using the 360 with the Sammy LE40M61BX?
Also do I have to manually have to change the settings each time I switch from say Sky on Ext1 and then to the 360 on component or should the settings be the same for both??
Since playing with the settings yesterday I seem to have made the 360 settings worse (bit darker and not as crisp) not to sure what I have done, so any help would be great!
Thanks!
P
Thanks!
P
