LE32R88BD Panel
Discussion in 'LCD & LED LCD TVs Forum' started by Bongzilla, Apr 22, 2007.
Tags:
  1. Bongzilla
    Bongzilla
    Apr 19, 2007
    7
  2. ic1male
    ic1male
    Dec 14, 2006
    28
    There are three it uses from reading another thread about it. But the once-was crappier panel is now apparently much better.
    I would take that Curry's comparison table with a pinch of salt.
  3. Rezler
    Rezler
    I was planning on purchasing the LE32R73BD, but then came across the R88. Which would be the better choice? Or is there better tv in the same price range. Main use would be for an xbox 360. Thanks.
  4. rd100
    rd100
    May 26, 2006
    237
    +13
