D
Deleted member 188495
how much difference is there between these 2 tv's i went to the shop showing the two, the r87 looked very bad. but the 37 inch version looked as good as the m87, im thinking the guy in the shop played with the setting to make the r87 look bad that it really is. the colours looked very dull and weak. so i preferred the m87 but i think it was just a trick to make me buy the more expensive tv. what do you guys think? any ond have either of these tv's as it will cost me an extra 100 pounds to go for the m87 rather than the r87 is this worth it? the only difference i know is the 100z
are there any simailar tv i should know about which are between 500 -600 pounds.
Thank you
Thank you
