LE32A456 sound prob - vibration?
Discussion in 'LCD & LED LCD TVs Forum' started by liam_h, Jun 17, 2009.
Tags:
  1. liam_h
    liam_h
    Feb 4, 2008
    I bought a Samsung LE32A456 last year and the sound has never been brilliant - with certain sounds and pitches of voice, the casing seems to vibrate/resonate. Turning the volume down or having less bass makes it better (not surprising) and if I use the audio outputs into a hi-fi the sound is spot on (with the telly muted to avoid the sound lag!)
    Has anyone else had a similar problem? It's starting to bug me now....!
    Rang Samsung as it's still under warranty and they are going to suggest some setting changes but I think the problem is physical rather than the settings. If it's easy to fix myself I'd rather not have to take a day off work for an engineer to come.
  2. Badger0-0
    Badger0-0
    May 30, 2005
    20,601
    Spaghetti Junction (really)
    +1,922
    I very much doubt you'll improve things.
    I've seen a few comments that basically the sound is just poor on some of the Samsungs.
    I'd just keep running it with the amp.
