le32a41b - no component?
Discussion in 'LCD & LED LCD TVs' started by thelawnet, Sep 1, 2005.
  1. thelawnet
    thelawnet
    Aug 21, 2005
    102
    Hi. Saw these reviewed at homecinemachoice. Two reviews, both stating no component input. This is fatal for xbox hdtv....
    Anyway, it is said on here that the a41b is the same as the r41b, which definitely does have component.
    So are those reviews accurate - does the a41b have it or not?
    FWIW, the place I'm looking at lists it as part number LE32T51B
    I don't want a TV without component input.
  2. thelawnet
    thelawnet
    Aug 21, 2005
    102
    nobody got one of these?
  3. laddage1
    laddage1
    Jan 8, 2005
    Just to confirm that the LE32A41B does not have component inputs. It looks like they upgraded the connectivity when they brought out the LE32R41B & also added phono audio outs & replaced the DVI connection with HDMI.
    Hope this helps
