LE26R41BDX no freeview working?
mrchipz
I have just bought the LE26R41BDX from Waratah.
Can i not get any freeview channels from the TV? I have connected only mains aerial and get normal 1-5 channels. When i press the DTV button it says no signal, can anyone help how to see freeview channels? :lease:
S
smallmanongn
In the first instance are you able to receive Freeview in your area?
Get an ariel installer to come and do a signal strenght test on your exisiting ariel to see if it is good enough.
JayCee
Why don't you read the manual :rolleyes: there is a separate setup menu for DTV
JayCee
Ariel is what you put in your washing machine.
The word is AERIAL...God, it's on this forum often enough.:rolleyes:
T
Tokyo_Postcode
True....you need to scan for digital channels using the DTV menu when you first get your tv. However, chances are you aren't picking up a strong enough signal anyway. You may need to install a better outside aerial, or it may just be that you can't pick up any signal in your area.
Like the previous post said, get an aerial engineer to come round and test your signal strength. Then they will be able to tell you what your best options are.
Worked for me, although I did have to shell out £75 on a new aerial....
bignige
Before you go off on one, you can't access the DTV menu if you can't get a signal. If it says no signal on screen, no button pressing will bring anything up. I have the same problem.
JayCee
Wrong...I installed one today, you scan for signals within the DTV setup menu.
The default on-screen message is "No Signal"...that's because you haven't tuned it yet. :lesson:
chriszzzzzz
Dont let this forum get like Digital Spy. All that has on it are grammar and spelling fascists.
As long as the question is understood and there is an answer then thats all the forum should be interested in. :)
JayCee
No, I don't agree :lesson:
I think people should make an effort, the extremely poor spelling and grammar put me off "Digital Spy".
This forum has better standards and I want it to stay that way. As I said, that particular word must be one of the most common that appear here and there is no excuse for getting it wrong.
C
Chanes
Do you spank those who don't listen and keep getting it wrong? :D
mrchipz
aerial is okay, as my last TV had integrated freeview.
Got it to work, did not realise it had a separate set up to normal TV!!! :clap:
The samsung instruction manual is good but could have been set up clearer for 1st time installation!
I mean you have to read p86 just learn to put screws for the base to the TV.
cheers all
JayCee
cheers all
Glad to hear you got it working :smashin: ...wonder if "bignige" managed his?
I agree the user manual is badly laid out.
bignige
Ok, boss, talk me through it. I bow down to your greater knowledge.
Nothing I do will get anything up. If I press DTV, it says "no signal".
If I press "DT Menu" it says "not available".
I have a seperate Freeview box which'll only pick up a few channels - I don't think I'm in the best place to receive it.
I have to agree about the grammar, don't be lazy people.
JayCee
Your model no definitely ends in "BDX"?
That's the suffix which means integrated Freeview.
bignige
Model no. does indeed end with BDX. It also has Freeview plastered all over the box.
Are you saying, even if I can't get a picture from freeview, I should still be able to access the menu?
bignige
I've just retuned my seperate Freeview on the Kitchen TV, it can receive about 20 odd channels, Not sure why I can't get this to work on the Samsung. Mrchipz, what did you do?
JayCee
Yes..without a shred of doubt.
Switch it to DTV...call up the setup/install menu, you then pick automatic search and you should get the on-screen bargraph searching from the left-hand side...as it searchs it displays the number of channels found.
If you don't get this there is something wrong.
bignige
Right, I've pressed the DTV button. It says no signal.
Then I've pressed the D.Menu button, the screen flashes black, agian says no signal.
Any ideas, am I doing this right?
JayCee
No, after pressing the DTV button, press the main menu button and use the down arrow till you get to the "install" (or is it setup?) menu..from there go into automatic search...try that. :smashin:
bignige
Pressed DTV, then the Main menu button, the only options available in set-up are TIME, BLUE SCREEN, MELODY & COLOUR WEAKNESS. The rest are greyed out eg. PLUG & PLAY etc.
JayCee
Right bignige this is how to do it.
Press DTV
Press D Menu
Down the left-hand side should be...
Guide
Preferences
Feature
Channel
System
Using the down arrow scroll down to Channel and press Enter.
You should then have "Autostore" already high-lighted...press the right arrow and the set should then display the on-screen bargraph and start searching left-to-right and displaying the number of channels found....this is dependent on aerial and reception quality.
Good luck. :smashin:
bignige
My TV is borked. Doing exactly as described above, when I get to pressing the D Menu I just get a black screen. Spoke to Samsung, was told it sounded faulty.
It's not the aerial, seperate Freeview box works fine, retuned it gets 84 channels.
Thanks for the help J.
JayCee
Bummer :thumbsdow
Hope you get it fixed or replaced then..good luck,
J.
chriszzzzzz
Sorry! This forum is better than Digital Spy, Thats because there are less spelling and grammar fascists on it.
The standard of information is superior. Hopefully it can be kept that way....
Trending threads
Latest news
T+A expands E-Series with PA 1100E integrated amplifier
  • By Andy Bassett
  • Published
Bowers & Wilkins unveils new PX wireless ANC headphones
  • By Andy Bassett
  • Published
Roku Premiere streaming device with 4K HDR hits UK
  • By Andy Bassett
  • Published
CTA launches 8K UHD TV display certification programme
  • By Andy Bassett
  • Published
Huawei launches Google-less Mate 30 and Mate 30 Pro phones
  • By Andy Bassett
  • Published
Latest threads
