LE2651B over LE2641B
Discussion in 'LCD & LED LCD TVs' started by mojo1080, Aug 8, 2005.
  1. mojo1080
    mojo1080
    Jan 27, 2005
    475
    +81
    Whats the crack ,the 51 model has 3000:1 contrast and the 41 has only 800:1 contrast ratio, and there both similary priced. Although Dixons online seem to be the only people knocking it out (LER51B).
    I'm lookin into buying a small LCD mainly for playing on a XBOX 360 but also as a monitor for my PC to go on the wall in a small room.
    I've borrowed a LER41B from work,and i'm using it now with my Pc, which is great. But hooking my Xbox up through component using 720p u get the odd screen tearing, only occasionally but not enough to get u down. Throgh HDMI it seems fine and via PC input it seems rock steady so far. Im just wondering if anyone has experience of the 51 model, and is it much better? any thoughts would be welcome :lease: , as I'm looking to buy in the next few weeks.
    Cheers Guys :smashin:
  2. mr-monday
    mr-monday
    Jul 19, 2004
    428
    28
    +31
    Nah they're both 800:1. 3000:1 isn't a true figure, just invented by the marketing men regarding some of the digital picture processing.
    The only differences between the two are cosmetic.
  3. mojo1080
    mojo1080
    Jan 27, 2005
    475
    +81
    cheers mate. I quite like the look of the 41 model , to be honest its one of the best Lcd's i've seen to look at. Is the 51 much different ?
  4. c.jelly
    c.jelly
    Jul 12, 2005
    222
    +3
