LCR2 as an "EX" in S2 package
Discussion in 'Home Cinema Speakers' started by Malone, Mar 12, 2001.
  1. Malone
    Malone
    Mar 12, 2001
    1,859
    Ilkeston,Derby
    +70
    I should shortly be getting an AX1 does the S2 package with an LCR2 as a "EX" speaker work well together and would it be better with 2X ASW2500(front and back) or one larger SUB
  2. Guest
    Sounds like it should be good - though be aware that the off axis response of the LCR6 is not great if you position it horizontally - better to go with the vertical if you can which is how the speaker was designed to be used. I've heard that two subs are better than one but haven't tried it out...
    enjoy.
