LCR and Atmos speakers placement on media wall advice
Petetheroadie
I'm getting a carpenter in to build shelves across the whole front wall of our living room. Here's the design, measurements etc.
Would love feedback/advice from this group about L & R and the 2 Atmos speakers placement in particular. Are they too far to the left/right given this is almost 5m wide? Are the Atmos speakers too high?
Seating position is 3.5m in front of this.
Thanks,
Pete
Petetheroadie
Thanks,
Pete
L & R speakers are Monitor Audio Radius 90, Atmos are Elac debut 4.2 upfiring
gibbsy
If you are using them in the upfiring position then you are simply far too high. The recommendation is not to have them set any higher than 50% of the height of the ceiling.
Petetheroadie
Thanks Gibbsy. Will measure up and see where on the shelves they should fit. Any opinion on the ideal distance from left to right (on both L&R and Atmos)?
gibbsy
The recommendation for using upfiring speakers is to have on top of or as near as possible to the front left and right speaker. If you cannot achieve that then slightly inside of them should be fine.
Petetheroadie
That should be doable, thanks
Re left to right distance. Left and right speakers will be about 4.7m apart. Does that sound ok or are there any beat practices here?
gibbsy
That seems a long way apart unless you're having a big screen and need to sit 4m from it. Where you are sitting think of a triangle, the left and right should be the same distance from you as they are apart.
Worth having a look at this guide.
Petetheroadie
Thanks, appreciate it 👍
Podcast: Anthem AVM 70 Review, EQing Your Home Cinema Sound System and More...
