LCD's with build in DVD player??
Discussion in 'LCD & LED LCD TVs' started by 6022tivo, Sep 7, 2005.
  1. 6022tivo
    6022tivo
    Aug 28, 2005
    637
    28
    +81
    Can you get them??
    If so, models and links please???
  2. andrewfee
    andrewfee
    Apr 27, 2004
    3,061
    +500
    Erm, unlikely, and I'm not quite sure why you'd want one?
    The player wouldn't compare in quality to a good upscaling HDMI one, and the drive itself (let alone the other components) is about 6x deeper than most LCD sets are. (I suppose it could be mounted on the side like the new iMacs though)
    Anyway, no I don't think anyone does them.
  3. 6022tivo
    6022tivo
    Aug 28, 2005
    637
    28
    +81
    It is for the MIL, bedroom...
    She wants it so she can just slot in the dvd's in the side??. I thought I had seen some around, maybe not.
  4. 6022tivo
    6022tivo
    Aug 28, 2005
    637
    28
    +81
    Ahh, have found some.. Argos product code 0870223... Will keep a looking.
    Does anyone have one and are they any good, what would you recommend
  5. mince bigalow
    mince bigalow
    I think you can get a 17" DMTech one in Dixons. Not that expensive either.
  6. 6022tivo
    6022tivo
    Aug 28, 2005
    637
    28
    +81
    Have found a 20inch one at currys product code 309367 £549.
    Neovia NEO2005DTX WHO???? anyone have one of these and can recommend??
