LCD with Freeview
Discussion in 'LCD & LED LCD TVs' started by suzy, Dec 21, 2004.
  1. suzy
    suzy
    I am looking for 17" LCD television that has freeview incorporated. can anyone help.
  2. Flashman
    Flashman
    Dec 3, 2002
    353
    Swindon, Wilts
    +11
    Suzy, there are a couple at the moment, the Toshiba 17WLT46 and the JVC LT17D50.....
    Both are in short supply at the moment, I'm currently waiting on an order for the Toshiba set....
  3. suzy
    suzy
    if there a web site for the toshiba and the JVC?, or where I can purchase them
  4. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    Humax & ICE as well
  5. Flashman
    Flashman
    Dec 3, 2002
    353
    Swindon, Wilts
    +11
    Lots of online retailers, but two I have used (and I'm sure there will be lots of positive/negative comments!) with good results are www.empiredirect.co.uk or www.unbeatable.co.uk. Try a search on the AV Forums hardware link....
  6. BobD
    BobD
    I have a Toshiba 17WLT46 and the picture quality on Freeview is very good as the digital data drives the screen directly with no analodue to digital conversion etc. Sensitivity of the freeview tuner is very as it picks up the BBC channels in Horsham West Sussex on a very old aerial even when the analogue picture is poor. Tested it on my friends high gain aerial and recieved all channels perfectly despite the postcode checkers stating I cannot receive all the channels. Compared the picture from Freeview with the analogue tuner using the high gain aerial and the Freeview is still much better due to the direct digital feed.
    Anyone contemplating purchasing a LCD TV without Freeview which drives the LCD panel directly will surely be disappointed with the result.
    Surprising there are not more LCD TV's with Freeview tuners considering how much the the tuner would cost to integrate into the TV.
    Full marks to Toshiba for providing the ideal solution and for designing it well.
    Have purchased a Televe DAT45 aerial with MRD and will erect over Xmas - this should sort my reception problem out.
