LCD wallmounting help
Discussion in 'Home Cinema Buying & Building' started by p3rfect, Feb 5, 2005.
  1. p3rfect
    p3rfect
    Oct 12, 2004
    16
    Hi quick question... I have a Panasonic TC-32LX20 32 Inch Viera LCD TV and wish to wallmount it. The official wall mount costs nearly £200, but I've seen 3rd party ones such as this http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/1810 which fits all "VESA compliant mounting systems" at £40. Would this or something sililiar (examples please?) be suitable?
  2. Judders
    Judders
    Oct 31, 2004
    154
    16
    Basingstoke
    Hi P3rfect,
    I recently wall mounted my Sharp 32GA4E. The Sharp bracket was £150, but I got a VESA 200 compatible one for £50 and it worked a treat :thumbsup:
    Here's the one I used: http://www.hifistore.co.uk/product.php?qsProd=Z847
    If your LCD's VESA compatible, which I'm sure it is, and you buy a VESA compatible bracket with the correct standard (75, 100, 200, etc) you should have no problems at all.
    HTH
    Jud
  3. AgentPingu
    AgentPingu
    Sorry to be the bringer of bad news, but I seem to remember that the Panny isn't a standard VESA fitment......think you have to have the official Panny mount.......wall mounts are a sore subject with me, I do nothing but moan about them!
    Best wait for other peoples expertise though.......any Panny owners out there???
  4. mark88
    mark88
    Oct 25, 2004
    878
    +23
    What type of screws of you using to mount the sharp?
  5. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Mark,
    Seems I have the same bracket as Judders. I went to Wickes and got 12mm bolts with metal collets/plugs on them for masonary. Solid as a rock.
    Richie.
  6. p3rfect
    p3rfect
    Oct 12, 2004
    16
    bugger..................
  7. Snyda
    Snyda
    as long as whoever manages to get it together guarantees some kind of assurance that if it not as you require you can get some kind of payment back
