LCD Wallmount - Samsung LE32R41B 32"
Discussion in 'Home Cinema Buying & Building' started by RealM, Jul 5, 2005.
  1. RealM
    RealM
    Jun 14, 2005
    28
  2. RealM
    RealM
    Jun 14, 2005
    28
  3. SteveW70
    SteveW70
  4. hamd01
    hamd01
    Mar 21, 2005
    959
    46
    Cumbria
    +145
    Doesnt it need to be VESA 200/200....the one you link to is 200/100
  5. SteveW70
    SteveW70
    Tha Samsung Site says it's Vesa 100/200 ? So presume by that they mean 200/100.
    Perhaps RealM should ring Samsung Technical or better still measure the fixing points on the back of the screen to make sure :smashin:
    Edit - Just checked the one I linked to and it will do Vesa 200/200 as well so I think it covers it either way :thumbsup:
  6. hamd01
    hamd01
    Mar 21, 2005
    959
    46
    Cumbria
    +145
    Its also 200x200 compatible, and if it was upto me I wouldnt want to stick something that expensive on my wayy using just 4 screws!!! Use 200x200 and 6 screws.
  7. RealM
    RealM
    Jun 14, 2005
    28
  8. SteveW70
    SteveW70
  9. RealM
    RealM
    Jun 14, 2005
    28
    I will have to measure them when i get back as i am at work at the moment. I will have to get back to you on that one.
  10. SteveW70
    SteveW70
    OK let me know.
  11. RealM
    RealM
    Jun 14, 2005
    28
    Right i have done a little diagram as thought it would be easier to follow
    [​IMG]
    Hope that helps..
  12. SteveW70
    SteveW70
    Nice diagram :thumbsup:
    Thats Vesa 200/200.
    Do you need the panel to tilt?
  13. RealM
    RealM
    Jun 14, 2005
    28
    Glad you like it :) Erm... I think i might as well get one that tilts. Any suggestions on which one to go for then?
    BTW: cheers for the help it is greatly appreciated :thumbsup:
  14. RealM
    RealM
    Jun 14, 2005
    28
    It seems the one you linked to before was 200/100 and it does not appear if they have 200/200 at chaseavdirect.
  15. hamd01
    hamd01
    Mar 21, 2005
    959
    46
    Cumbria
    +145
    Have a look on eBay for a tilting 200x200, I picked mine up for £69
  16. RealM
    RealM
    Jun 14, 2005
    28
    None on ebay and need one asap really as i don't have a TV to watch at the moment.
  17. SteveW70
    SteveW70
    RealM,
    Have a look at this one.
    I've used ChaseAV a few times and they're a really helpful, reliable company. :smashin:
    Hope this helps.
  18. RealM
    RealM
    Jun 14, 2005
    28
    Which one, No link there pal ??
  19. hamd01
    hamd01
    Mar 21, 2005
    959
    46
    Cumbria
    +145
  20. RealM
    RealM
    Jun 14, 2005
    28
    Sorry about that i had to look very quick as i am at work. Think i will have to go with that one then. Cheers for everyones help.
  21. SteveW70
    SteveW70
  22. RealM
    RealM
    Jun 14, 2005
    28
    Cheers pal, ordered one :)
  23. mickbarlow
    mickbarlow
    Dec 1, 2004
    532
    +7
    seems a bit expensive all this mounting bracket stuff.
    i have a friend who owns an aluminum factory costs him just over a quid to make a simple bracket!
  24. SteveW70
    SteveW70
    I'd go into business with him then Mick, I reckon you could make a killin' :smashin:
    I've thought exactly the same myself when buying a few brackets, bit of a rip off if you ask me :(
