LCD Virgin
Discussion in 'LCD & LED LCD TVs Forum' started by iamhoey, May 1, 2005.
Tags:
  1. iamhoey
    iamhoey
    Hey guys,
    I have been looking around this board for the past you days, you seem like a nice lot! I was wondering if you could help me with a hard choice I have to make about a new LCD TV. I have an absolute maximum of £1000. I was looking at a screen around 26 inch. At first I was looking at the Samsung LW26A33WX/XEU which is £999 at comet. It looks really nice, but I haven't read any reviews of it! Does anyone have one, or have any experiences of one?
    Also does anyone know if this TV would be "HDTV Ready"? For connections it has:
    Digital Interface (DVI-HDCP)
    Scart Jack - 2EA
    PC Input - D-Sub
    PC Audio
    I am also thinking of getting the JVC THSW-8 Home Cinema System with it, which has progressive scan, would the TV be able to benefit from this?
    I am really sorry for all my stupid questions, as I said I am new to this!
    Thanks in advance for any help you can give me!
  2. Contact
    Contact
    Oct 17, 2004
    64
    I don't have much experience with Samsung LCD's, they do make Sony's panels (but that doesn't mean much, Panasonic make their own and they're certainly not the best, it's all about the electronics behind the panels really).
    I'd expect to have more connections than those stated. Technically it'll work with Sky's HDTV, but you need component video inputs to be totally High Definition.
    Unless you've got a very high end DVD player/recorder, that connection isn't much use for the time being. But double checking the connections, there's two scarts. Doesn't mention if they're RGB/S-video or just standard, so I'd check that with Comet. They both should be RGB (it's clearer than standard, same with S-Video, but RGB's the better mode of the two).
    What are you connecting to the TV (ie. your DVD/video, is it a scart connection)?
    PC input's useful to give you an easy option to hook your PC up but it'll be up to you whether that's any use.
    On the subject of the JVC THSW8, it'll connect with RGB or S-Video Scart. The component video connection is the one that runs on progressive. If the TV doesn't have that connection, then it won't run.
    Most TV's run on 'interlace' and draw half the number of lines on one frame and the other half on another. Don't confuse with this with the flicker-free 100hz and flicker 50hz technologies, it's unrelated. 'Progressive' runs by drawing both lines at once, making the picture theoretically twice as detailed. Sometimes it looks better without, but more often than not it's easily the best setting. If you connect the THSW8 on component, it'll always be on that mode.
    Trick to the analogue connections. A scart can emulate each one.
    Composite - Regular Scart = Average connection (some extra movement on colour)
    S-video - Y/C Scart = Clean connection
    Component - RGB Scart = Top end connection
    Scart's the convient version. The only except is component, because RGB scart can't do progressive, and component is slightly better on non-progressive anyway.
    I'm in a rush so I'll stop here, feel free to ask any questions.
  3. jimg
    jimg
    Jul 4, 2004
    826
    +58
    Not sure what you are saying , if the set has DVI-HDCP then that is what you need for SKY HDTV. You will need a HDMI->DVI cable, but that is it!
  4. iamhoey
    iamhoey
    Hey Contact, thanks for replying so quickly!
    Samsung quote on their specs page it to have
    Scart Jack - 2EA
    PC Input - D-Sub
    PC Audio
    but Comet (in all their wisdom!) say:
    Scart sockets 2
    RGB scart sockets 1
    S-Video socket Yes
    Component video connection No
    Composite video input No
    AV inputs Yes For easy connection of equipment such as camcorders or games consoles.
    HDMI connection No
    DVI connection No
    HDCP enabled No
    RGB PC in Yes
    Optical connection Yes .
    Co-axial digital input No
    VGA compatible No
    SVGA compatible No
    XGA compatible Yes
    The only other vague info is from a German Ebay site:
    Digitaler Bildeingang (DVI-HDCP)
    PC-Anschluss (D-Sub)
    S-Video-Anschluss
    AV-Eingänge (AV entrances? is that component?)
    2 Scart-Anschlüsse
    Lautsprecher Ausgänge (Loud speaker connection?)
    Kopfhöreranschluss (Headphones)
    Mind you the German site was a bit weird, but it did have the fun title of "HDTV was ist das?". Oh and it also says that it has a "dissolution of 1280 x 768".
    Anyway, that was a random stream of uselessness.
    It seems that it is definitely HDTV compatable, despite Comet.
    So the Samsung and the JVC has RGB, so I guess that is the best connection? and it will run progressive scan?
    I think I will just be connecting the JVC and possibly my laptop (via normal VGA connection).
    Contact, you seem to know your stuff, do you think that this will be money well spent? I don't want to waste over a £1000 and then regret it (I am a poor student!)
    I am sorry this post is a bit confused! It is very late!
    If anyone has any experiences of either the Samsung or the JVC, I would be really greatful if you would let me know you experiences!
  5. Contact
    Contact
    Oct 17, 2004
    64
    I mean from the point of view that to be HDTV Ready, you need a component input too.
    iamhoey, it seems like there's a mixed message. So we'll assume the TV has:
    One DVI HDCP socket (for Sky HDTV)
    One RGB Scart
    One Normal (maybe S-video?) Scart
    One set of composite and S-video side connections
    PC input
    And apparently an Optical connection. From all that, I'd advise running the THSW8 with an RGB Scart connection into the TV. You can't use Progressive Scan there, but the image won't be dramatically different. It'll give a solid picture.
    Honestly, you need to have a good look at this TV instore and running. Check out how it handles movement (for instance a DVD image, does the detail fade whenever things shift about and come back when it's paused?).
    My personal feeling on LCD is, you either go for quality or don't buy one at all. A cheap LCD is still a lot more than a Cathode Ray Tube equivalent. Also, this is the time of a lot of range changes, so there's more bargains for the old and lots of interesting new stuff.
    How much are they doing the THSW8? I thought it was down to £199 (deal price because it's the last range, though Comet seems to think most of JVC's now old range is yet to be released!). It's a good TV, but that wireless reciever seems more of a pain than just putting the wires round the room. Then again, I'm not sure the wired version's any cheaper, plus the omni directional speakers are good with the THSW8.
  6. WoodyC
    WoodyC
    Feb 7, 2005
    47
    9
    I've literally just bought the 32" version of the Samsung yesterday afternoon (after running around various Currys as no one had any in stock). It's not properly set up yet but overall I've been quite impressed with the picture quality. I'm using old scarts at the moment so they aren't exactly doing the TV any favours as well.
    I can't comment on the connections but if the 26" does have component then it should look fine. I demo'd (briefly) the opening of Matrix Reloaded via component while I was in Currys and it looked really good.
    The only flaws I've seen so far were during the Snooker, where it had a little trouble with smearing of colours. To be honest it isn't actually that bad but if you really want to be picky then you'll see it.
    Hope this helps
  7. sapper44
    sapper44
    Feb 12, 2004
    551
    uk
    +64
    What ever LCD you buy.You must make sure it's ready for hi-def that means it must have a resolution of 1280*720 anything less than that and it will not be hi-def.
    You also want a DVI or HDMI connection as well as RGB scart and a set of component connection.A pc connection is good as well.I think Phillips pixel plus LCD are one of the best at the mo haven't seen any good rightups on it as yet so its worth looking into.
  8. jimg
    jimg
    Jul 4, 2004
    826
    +58
    I take it it you are talking about the HD Ready logo, that has been changed to remove the requirement for component. You do not really need component for HD.
  9. Contact
    Contact
    Oct 17, 2004
    64
    Ah right, I wasn't aware that had changed.
    Well for the surround system and most of the other DVD players and Recorders, at the moment at least, component is the most common top-end connection. So while the DVI HDCP'll come into its own eventually, component is very welcome support. There's planning ahead, but it's also nice to be able to make use of the here and now.
  10. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    Eh? You are obviously not a regular on this part of the Forum! The Philips LCD's have literally thousands of posts on here concerning them.
    Jimmy
