LCD under 20inch for the bathroom?
Discussion in 'LCD & LED LCD TVs' started by Mr_Tony, Aug 5, 2005.
  1. Mr_Tony
    Mr_Tony
    Jun 17, 2005
    113
    16
    Can someone recommend a lcd tv under 20inch, that i will be using in my bathroom please?
    dont want to spend more than 500 really.
  2. Shonte
    Shonte
    Aug 4, 2005
    132
    Dont have it on the side of the bath :D
  3. northernmunki
    northernmunki
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
  5. Mr_Tony
    Mr_Tony
    Jun 17, 2005
    113
    16
    thats a bit more than i want to spend... 37inc in the bathroom!? crazy
  6. neilball
    neilball
    Jan 7, 2005
    2,601
    Scottish Borders
    +515
    www.tricustom.co.uk
    look at the spavision - an in-wall housing for a Sharp Aquos 15" LCD TV. Housing & LCD for under a grand.
  7. Shakey_Jake33
    Shakey_Jake33
    Asda have some for roughly 200. Not exactly uber quality mind, but if it's just for the bathroom...
  8. Mr_Tony
    Mr_Tony
    Jun 17, 2005
    113
    16
    thats pretty cool that spa thing, ive done this wrong though, i have just had it decorated and tiled, i should have done this before
  9. slowpoke
    slowpoke
    Jul 11, 2005
    1,077
    41
    Maidenhead
    +17
    just listen to radio 5 like most people!! why would you want a Tv in the bathroom?? each to their own I suppose!
  10. Mr_Tony
    Mr_Tony
    Jun 17, 2005
    113
    16
    i want to sit in the bath and relax and watch tv...
    i did it on holiday and got the taste for it
  11. neilball
    neilball
    Jan 7, 2005
    2,601
    Scottish Borders
    +515
    If the wall is now tiled then you need to use one of the rotozip type tools (spiral saw) to create the opening assuming it is a stud wall that has been tiled - you just need to miss any studs in the wall! With the correct bit it cuts very neatly, and the cut edge gets covered by the front steel & glass panel. It might be more difficult getting the cables to the potential screen location depending on wall construction i.e. external solid wall or internal partition.
    HTH
  12. Mr_Tony
    Mr_Tony
    Jun 17, 2005
    113
    16
    its ok now, i am having it on the one wall and its only plastered. So itll glide through
  13. Mr_Wistles
    Mr_Wistles
    Mar 11, 2004
    11,795
    Essex
    +2,955
    Did you get this done Tony?
    I am thinking of doing it myself. How did you hook it up to a source?
