LCD TV's - should they buzz?
Discussion in 'LCD & LED LCD TVs' started by Dave N, Dec 19, 2004.
  1. Dave N
    Dave N
    Feb 11, 2002
    111
    16
    Herts
    Have just acquired a Sharp 15". It has quite a noticable high pitch buzz/hum which varies in volume depending on the Brightness setting (!). Is this "normal" behaviour?
    Dave :confused:
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,112
    Manchester
    +713
    I don't have a Sharp but the sound you are hearing sounds like it's power supply related, e.g. a coil or transformer in a switch mode supply with vibrating core.
    You should email Sharp unless you can find someone here (or elsewhere) with the same display so that you can compare notes - and perhaps settings.
    Chris Muriel (normally in Manchester but currently in Tel Aviv on business).
  3. ginger
    ginger
    It could be that the backlight brightness is controlled by modulation, hence with a high brightness setting you won't hear it (always on). This seems to be the case with my Tosh where I can hear a buzzing noise at backlight settings lower than 75%. The noise was something I couldn't live with, so I have my backlight set at 75% and adjusted other settings to get an acceptable picture. Always worth checking with Sharp though
  4. Dave N
    Dave N
    Feb 11, 2002
    111
    16
    Herts
    Turns out to be a known fault with a batch of Aquos LC15S1E - Sharp will collect and repair or, as in my case, John Lewis, will simply swap it.
  5. Digitised
    Digitised
    Oct 11, 2004
    177
    +13
    only my ambilight buzzes, when i switch it off even a massive 20kg lcd is slient.
