LCD TVs - quick help please
Discussion in 'LCD & LED LCD TVs Forum' started by FeedTheFreak, Jul 10, 2003.
Tags:
  1. FeedTheFreak
    FeedTheFreak
    Dec 9, 2002
    17
    3
    London
    Hi people
    Can anyone recommend an LCD TV - it would be a second TV to go in the bedroom, and I'd spend up to £1000.
    Any and all advice or recommendations please!
    FtF
  2. GAmbrose
    GAmbrose
    Jul 5, 2003
    996
    43
    Essex
    +184
  3. FeedTheFreak
    FeedTheFreak
    Dec 9, 2002
    17
    3
    London
    OK OK, thanks, I didn't see it in my haste to post...
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,383
    Somewhere in South Yorkshire
    +5,770
    Some questions thar might help solicit an answer:
    - 4x3 or 16x9?
    - preferred size?
    - will you need to watch it from below the horizontal?
  5. FeedTheFreak
    FeedTheFreak
    Dec 9, 2002
    17
    3
    London
    Prefer 16x9, I think. For bedroom so not too big, and probably would watch it from below the horizontal, yes.
  6. LV426
    LV426
    Jul 14, 2000
    13,383
    +5,770
    You could do worse, then, than the Grundig 17 inch item on sale at Dixon$ (much as I hesitate to recommend that anyone buys anything from D$G). It has a wide viewing angle up, down left, right (not true of all LCDs) with a high resolution panel and a fairly decent scaler. IIRC, GBP700.
    DO NOT consider the Panasonic 15 inch item (with or without onboard DVD) because it has a very poor below the horizontal viewing angle.
    Other options - 15 and 17 inch items from Samsung (check the viewing angle on these, they aren't all the same) and the Sharp Aquos series.
    There are probably others; the easiest to see demo'd is the Grundig.
    Larger? 22 inchers from Samsung (LW22A13 - don't bother visiting Samsung's website, it ain't there) and Sharp Aquos. Both come out at over GBP1000 though.
  7. FeedTheFreak
    FeedTheFreak
    Dec 9, 2002
    17
    3
    London
    Thanks, Nigel. that's a start. Anyone else got an opinion?
  8. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,215
    83
    Over the Hill & Far Away
    +135
    See my thread further down about first time LCD's and also the review of the Relisys 1720.. 17" widescreen good veiwing angle and connections.. and £200 cheaper than the grundig!
    HTH
    Matt
