LCD TV wont work with my LCD TV
Discussion in 'LCD & LED LCD TVs' started by rdjmoose, Jun 26, 2005.
  1. rdjmoose
    rdjmoose
    Hi, This is my first post and I am in desperate need of a solution.
    I bought a Relisys RLT1730 17" LCD TV and it seems to work fine when I connect any AV sources except the one that I want it to, namely a new TRANWO GigaAir 2424 video sender. :(
    I tried the sender on 2 other (crt) tv's and it works fine. I connect the scart input to my new lcd and at best all I can get is some very poor quality sound and a fuzzy almost impossible to see image, that jumps.
    I have tried every menu setting etc and nothing works. I was wondering if anybody has an idea about what is going on, is it to do with the Relisys not decoding the signal properly because if I connect another av soucr such as a dvd player it works fine :confused:
    Please if anyone can offer a solution I would be very grateful.
  2. rdjmoose
    rdjmoose
    Just to add. I looked through some other posts and it seems there may be problems with LCD TV's and video senders, is this a well known problem, and is there a way around it?
    Thanks again for any advice.
  3. Andy3
    Andy3
    Jun 20, 2005
    634
    Cheshire
    +19
    This is interesting. When our Pana CRT blew up, I brought our bedroom telly (a Grundig 17" LCD) down so we had something to watch until we could buy a new one. As it doesn't have much in the way of sockets, I daisy-chained everything via RF. Everything worked except the video - the auto tune on the TV just couldn't see it! So I went through the channels manually until I came across it, but I could only hear the sound - the TV stubbornly stayed on 'blue screen'.
    I thought perhaps the output of the video was off-channel, so I carefully tweaked the modulator and tried again. No luck.
    I have no idea why it wouldn't have it, but it might be similar to your problem.
    EDIT: Our new JVC LCD works a treat with the same setup :rolleyes:
  4. rdjmoose
    rdjmoose
    I managed to get it working but only after plugging the scart from the video sender into a VCR and then plugging the vcr out to the tv. Why this works and just plugging it straight into the tv I have no idea.
    Would there be a simpler way to achieve this without having the vcr in the middle?
  5. ian watson
    ian watson
    Jun 1, 2005
    33
    Hi.
    I just got a RLT1730 today. I have a video sender and Sky tv working ok with it. I tested the video sender direct into the tv and it was ok.
    I currently have video sender in the Sky box, Sky box into a SCART splitter, which sends the signal to the tv, and my computer.
    Took a while to set up (AV picture on for a second then went to tv), then found how to turn the "scart switch control" off in the menu - its in "reset" menu for some reason.
  6. rdjmoose
    rdjmoose
    That is strange as mine just doesn't work directly with the tv, and I don't know why. I tried it through a splitter and it didn't work either, I actually needed to run it through a seperate source (the vcr) which is annoying because I don't even have any videos and it is another box in the bedroom
