lcd tv- with or without freeview???
Discussion in 'LCD & LED LCD TVs Forum' started by jules19, Jun 3, 2005.
Tags:
  1. jules19
    jules19
    i am wanting to purchase an lcd screen for my lounge- i am not a gamer, nor will i be hooking it up to a pc.
    at the mo it will be hooked upto a denon 500sd- so this will be done via component.
    I obviously want to purchase a relatively future proof tv, so am looking for a tv that has both hdmi and component, just in case i opt to get rid of the denon and buy a hd dvd player.
    but with regards to the screen is it really necessary for me to have IDTV if everything will be running through my NTL set top box.
    is the advantage of idtv having the freeview built in and can act as a stand alone without the need for sky or cable??? or is it something else- am i missing something.
    please help
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    A lot depends on what channels you are used to getting on cable. Freeview gives digital quality, but apart from TopUp TV, there is little in the way of subscription channels. The addition of Freeview adds quite a lot to the price of the TV, so it's pointless buying it if you just think you might need it in the future.
  3. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    You can get Freeview decoders to plug in over an RGB SCART input for tiny prices,a nd these will only fall in the future. So, I wouldn't worry about that too much.
  4. jules19
    jules19
    i can only surmise then, that it would be cheaper for me to buy a tv and then also purchase a concomitant freeview box ???? because based on that - i could buy the samsung 32 hdmi compliant from empire direct and also pick up a cheap freeview box, whic would approximitaely render me £800, rather than paying £1049+ for the same tv with freeview
    is it really that simple???
    so based on what i receive through cable tv should determine whether i pick up a freeview box
    thanks
  5. matt_p
    matt_p
    Apr 7, 2005
    851
    28
    Nottingham
    +38
    I can't think of anything on Freeview that you wouldn't be getting on NTL anyway... I wouldn't bother with a freeview box.
