LCD-TV Viewing Angles Filtering Table.
Discussion in 'LCD & LED LCD TVs Forum' started by Har-One, Sep 13, 2016.
  1. Har-One
    Har-One
    Jan 16, 2009
    4,871
    167
    UK
    +2,900
    • To see all Viewing Angles for a particular Viewing Distance type in the filter field '9ft'
    • To see all Seating Distances for for a particular Viewing Angle type in the filter field '30-degrees'
    Seating Distance ft Seating Distance m Viewing Angle Viewing Distance ft Viewing Distance m
    1 6ft 1.83 10-degrees 2.1 0.64
    2 6ft 1.83 15-degrees 3.2 0.98
    3 6ft 1.83 20-degrees 4.4 1.33
    4 6ft 1.83 25-degrees 5.6 1.71
    5 6ft 1.83 30-degrees 6.9 2.11
    6 6ft 1.83 35-degrees 8.4 2.56
    7 6ft 1.83 40-degrees 10.1 3.07
    8 6ft 1.83 45-degrees 12.0 3.66
    9 6ft 1.83 50-degrees 14.3 4.36
    10 6ft 1.83 55-degrees 17.1 5.22
    11 6ft 1.83 60-degrees 20.8 6.34
    12 6ft 1.83 65-degrees 25.7 7.84
    13 6ft 1.83 70-degrees 33.0 10.05
    14 7ft 2.13 10-degrees 2.5 0.75
    15 7ft 2.13 15-degrees 3.8 1.14
    16 7ft 2.13 20-degrees 5.1 1.55
    17 7ft 2.13 25-degrees 6.5 1.99
    18 7ft 2.13 30-degrees 8.1 2.46
    19 7ft 2.13 35-degrees 9.8 2.99
    20 7ft 2.13 40-degrees 11.7 3.58
    21 7ft 2.13 45-degrees 14.0 4.27
    22 7ft 2.13 50-degrees 16.7 5.09
    23 7ft 2.13 55-degrees 20.0 6.09
    24 7ft 2.13 60-degrees 24.2 7.39
    25 7ft 2.13 65-degrees 30.0 9.15
    26 7ft 2.13 70-degrees 38.5 11.72
    27 8ft 2.44 10-degrees 2.8 0.86
    28 8ft 2.44 15-degrees 4.3 1.31
    29 8ft 2.44 20-degrees 5.8 1.78
    30 8ft 2.44 25-degrees 7.5 2.27
    31 8ft 2.44 30-degrees 9.2 2.82
    32 8ft 2.44 35-degrees 11.2 3.41
    33 8ft 2.44 40-degrees 13.4 4.09
    34 8ft 2.44 45-degrees 16.0 4.88
    35 8ft 2.44 50-degrees 19.1 5.81
    36 8ft 2.44 55-degrees 22.9 6.96
    37 8ft 2.44 60-degrees 27.7 8.45
    38 8ft 2.44 65-degrees 34.3 10.46
    39 8ft 2.44 70-degrees 44.0 13.40
    40 9ft 2.74 10-degrees 3.2 0.97
    41 9ft 2.74 15-degrees 4.8 1.47
    42 9ft 2.74 20-degrees 6.6 2.00
    43 9ft 2.74 25-degrees 8.4 2.56
    44 9ft 2.74 30-degrees 10.4 3.17
    45 9ft 2.74 35-degrees 12.6 3.84
    46 9ft 2.74 40-degrees 15.1 4.60
    47 9ft 2.74 45-degrees 18.0 5.49
    48 9ft 2.74 50-degrees 21.5 6.54
    49 9ft 2.74 55-degrees 25.7 7.84
    50 9ft 2.74 60-degrees 31.2 9.50
    51 9ft 2.74 65-degrees 38.6 11.77
    52 9ft 2.74 70-degrees 49.5 15.07
    53 10ft 3.05 10-degrees 3.5 1.07
    54 10ft 3.05 15-degrees 5.4 1.63
    55 10ft 3.05 20-degrees 7.3 2.22
    56 10ft 3.05 25-degrees 9.3 2.84
    57 10ft 3.05 30-degrees 11.5 3.52
    58 10ft 3.05 35-degrees 14.0 4.27
    59 10ft 3.05 40-degrees 16.8 5.12
    60 10ft 3.05 45-degrees 20.0 6.10
    61 10ft 3.05 50-degrees 23.8 7.26
    62 10ft 3.05 55-degrees 28.6 8.71
    63 10ft 3.05 60-degrees 34.6 10.56
    64 10ft 3.05 65-degrees 42.9 13.07
    65 10ft 3.05 70-degrees 54.9 16.75
    66 11ft 3.35 10-degrees 3.9 1.18
    67 11ft 3.35 15-degrees 5.9 1.80
    68 11ft 3.35 20-degrees 8.0 2.44
    69 11ft 3.35 25-degrees 10.3 3.13
    70 11ft 3.35 30-degrees 12.7 3.87
    71 11ft 3.35 35-degrees 15.4 4.70
    72 11ft 3.35 40-degrees 18.5 5.63
    73 11ft 3.35 45-degrees 22.0 6.71
    74 11ft 3.35 50-degrees 26.2 7.99
    75 11ft 3.35 55-degrees 31.4 9.58
    76 11ft 3.35 60-degrees 38.1 11.61
    77 11ft 3.35 65-degrees 47.2 14.38
    78 11ft 3.35 70-degrees 60.4 18.42
    79 12ft 3.66 10-degrees 4.2 1.29
    80 12ft 3.66 15-degrees 6.4 1.96
    81 12ft 3.66 20-degrees 8.7 2.66
    82 12ft 3.66 25-degrees 11.2 3.41
    83 12ft 3.66 30-degrees 13.9 4.22
    84 12ft 3.66 35-degrees 16.8 5.12
    85 12ft 3.66 40-degrees 20.1 6.14
    86 12ft 3.66 45-degrees 24.0 7.32
    87 12ft 3.66 50-degrees 28.6 8.72
    88 12ft 3.66 55-degrees 34.3 10.45
    89 12ft 3.66 60-degrees 41.6 12.67
    90 12ft 3.66 65-degrees 51.5 15.69
    91 12ft 3.66 70-degrees 65.9 20.10
    92 13ft 3.96 10-degrees 4.6 1.40
    93 13ft 3.96 15-degrees 7.0 2.12
    94 13ft 3.96 20-degrees 9.5 2.88
    95 13ft 3.96 25-degrees 12.1 3.70
    96 13ft 3.96 30-degrees 15.0 4.58
    97 13ft 3.96 35-degrees 18.2 5.55
    98 13ft 3.96 40-degrees 21.8 6.65
    99 13ft 3.96 45-degrees 26.0 7.92
    100 13ft 3.96 50-degrees 31.0 9.44
    101 13ft 3.96 55-degrees 37.1 11.32
    102 13ft 3.96 60-degrees 45.0 13.73
    103 13ft 3.96 65-degrees 55.8 16.99
    104 13ft 3.96 70-degrees 71.4 21.77
    105 14ft 4.27 10-degrees 4.9 1.50
    106 14ft 4.27 15-degrees 7.5 2.29
    107 14ft 4.27 20-degrees 10.2 3.11
    108 14ft 4.27 25-degrees 13.1 3.98
    109 14ft 4.27 30-degrees 16.2 4.93
    110 14ft 4.27 35-degrees 19.6 5.98
    111 14ft 4.27 40-degrees 23.5 7.16
    112 14ft 4.27 45-degrees 28.0 8.53
    113 14ft 4.27 50-degrees 33.4 10.17
    114 14ft 4.27 55-degrees 40.0 12.19
    115 14ft 4.27 60-degrees 48.5 14.78
    116 14ft 4.27 65-degrees 60.0 18.30
    117 14ft 4.27 70-degrees 76.9 23.45
    118 15ft 4.57 10-degrees 5.3 1.61
    119 15ft 4.57 15-degrees 8.0 2.45
    120 15ft 4.57 20-degrees 10.9 3.33
    121 15ft 4.57 25-degrees 14.0 4.26
    122 15ft 4.57 30-degrees 17.3 5.28
    123 15ft 4.57 35-degrees 21.0 6.40
    124 15ft 4.57 40-degrees 25.2 7.67
    125 15ft 4.57 45-degrees 30.0 9.14
    126 15ft 4.57 50-degrees 35.8 10.90
    127 15ft 4.57 55-degrees 42.8 13.06
    128 15ft 4.57 60-degrees 52.0 15.84
    129 15ft 4.57 65-degrees 64.3 19.61
    130 15ft 4.57 70-degrees 82.4 25.12
