LCD TV - HiDef ready with DVB Tuner - question
Discussion in 'LCD & LED LCD TVs' started by MilesR, Mar 21, 2005.
  1. MilesR
    MilesR
    Hi all
    I (like everyone else ;) ) am looking into buying a 32" LCD TV.
    However, I'd prefer one that includes a DVB tuner.
    The reviews on the Toshiba 32WL48 look fantastic, but no DVB tuner.
    However, an answer to this question might swing it for me...
    When the broadcasters start broadcasting HD signals (e.g. the BBC in 2010) - does anyone know whether the internal DVB tuners be able to handle these and display in HD quality?
    If people say no, then I'll be going for the Tosh and a seperate freeview box (to be replaced in 2010 ;)) - if yes, then I'll wait for the next 32" with built-in DVB (and with a good review!)
    Cheers for the info
    Miles
  2. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    The BBC don't know themselves what format they will be broadcasting HDTV in. They have their own CODEC that they are evaluating. It certainly won't be in any decoders that exist commercially at present. In addition, most internal DTV tuners are connected internally via an SD RGB connection. So even if it was possible to do a s/w upgrade in 5 years time, you could only view it in SD.
    But i-DTV tuners do generally produce a better PQ than most STB's.
    -Ian
  3. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    Surely the BBC will be broadcasting alongside Sky over HD satellite next year? The Tosh is a sensible purchase and a Freeview box a fair enough 'filler' until HD STB's are relaesed by Sky next year.
    Jimmy
  4. MilesR
    MilesR
    Thanks for the replies guys.
    I don't currently have Sky and no plans to get it either. (I really don't watch enough TV to warrant it).
    So its really only the DVB that I'll be concerned with. I know its still 5 years away for terrestrial broadcasts to come out in HD (according to the BBC anyway), and by which time I'll probably have to buy another STB anyway...but I figured I might as well buy a TV with an integrated DVB tuner anyway. I've read that there are quite a few more sets being released in the next few months so might just hang on.
    It surprises me that with the analogue cut-off only a few years away manufacturers are still making TVs without the integrated DVB tuners. I know that a lot of people may have cable/Sky - but they have to assume that people don't have it.
    In the meantime I'll keep reading the mags and checking out the forums for info.
    Cheers!
    Miles
  5. BobD
    BobD
    There was a thread recently which stated that Toshiba will be introducing a new range of LCD tv's available with integrated freeview tuners - 32WLT56 was the model.
    Also the Panasonic range which has the freeview tuner now will be upgraded to have a digital DVI or HDMI input.
    Some advanced info of future SONY lcd tv's indicates they may have freeview and digital inputs.
    The picture on my Toshiba 17WLT46 lcd tv using the integrated freeview tuner is really good as I presume there is no digital to analogue and then analogue to digital conversion process which you would have if you used an external freeview tuner on a scart input. the picture is really much better than analogue terestrial and also better that the best picture on SKY.
    So wait and see....
  6. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    +9
    Hmmm. Bit of a sweeping statement there Bob!
    I would say that some Sky channels (ITV, Ch5, SKY) are possibly better than Freeview, and others (BBC) perhaps not as good. But to say that Freeview DVB is better across the board is misleading.
    Jimmy
  7. DaveBUK
    DaveBUK
    Mar 25, 2004
    49
    Dorset
    The thread is http://www.avforums.com/forums/showthread.php?t=195884 and the models are :
    Analogue tuner
    23WL56
    27WL56
    32WL56
    37WL56
    All available May 05
    Digital Freeview tuner
    27WLT58 available Aug 05
    32WLT58 available Aug 05
    37WLT58 available Sep 05
    42WLT58 available Oct 05
    Dave
  8. BobD
    BobD
    Jimsan,
    Sweeping statement or not?
    Well consider what some people consider to be the best LCD tv around today the Philips 9986 connected up to a SKY box via an RGB Scart cable or similarly connected up to a Freeview box via a RGB Scart cable.
    Now the digital picture obtained from the decoder will be converted to an analogue signal for transmission down the scart cable to the tv. This analogue signal will then be converted back into a digital signal in the tv before it can be shown on the digital LCD screen. Unless the frequency response of both conversion processes is much higher than the video bandwidth of the signal conversion then errors will be introduced. This is why there is so much interest in using HDMI and DVI connections wherever possible to transmit a truly digital video signal from DVD players etc. The use of an internal Freeview decoder in a digital tv enables the digital decoder output to be displayed directly on the digital LCD screen and will result in the best possible representation of that video picture.
    In my opinion all digital tv's should have an internal freeview decoder if only to ensure they are truly future proof and as good as the present LCD tv's are there is no doubt that the next generation will be truly digital.
    A lot of the picture settings we see for these LCD digital tv's are really a bit of a bodge to obtain the best picture with a relatively poor analogue source.
    I suggest you audition a good LCD tv with an internal freeview decoder and then give us your opinion.
    BobD
  9. MilesR
    MilesR
    DaveBUK - thanks for that info on the Tosh LCDs
    Looks like I'll wait till the Autumn and re-decide then - since I would prefer one with built-in DVB tuner.
    The 32WLT58 sounds like the one for me (providing its as good as the 32WL48 seems to be)
    Miles
  10. ianh64
    ianh64
    Aug 7, 2004
    2,233
    +63
    On all implementations of i-DTV tuners that I have seen, including displays with digital inputs, the internal tuner has been connected by good old SD RGB analogue. No direct digital interface. The benefit in quality is due to how tight this integration is, no long lengths of cable or external sockets.
    -Ian
  11. BobD
    BobD
    The Toshiba 17WLT46 LCD TV with i-DTV can display the analogue picture and the digital freeview picture side by side at the same time which would imply that there are 2 video speed analogue to digital converters in the tv. Since these devices are not cheap this is unlikely to be the case just to provide the dual picture funtion.
    BobD
  12. ianh64
    ianh64
    Aug 7, 2004
    2,233
    +63
    Sounds like standard PIP functionality to me. My screen can do it with 2 analogue tuners or a number of the external analogue inputs too. But it sort of blows your digital link theory out of the water since most screens that most screens cannot PIP their digital input with an analogue on (and often the HD component inputs too) as these are introduced into the video chain well after the PIP functions have taken place.
    -Ian
  13. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    new panny Veira LCD are DVB and HDMI HDready..............worth a look 26" and 32" sizes IIRC
  14. VurtHed
    VurtHed
    Dec 11, 2002
    194
    +6
    TX26LXD1
    TX32LXD1
    No D-Sub or DVI/HDMI by looks of it.
    Reviews here and here suggests 32" may not even support HD! ( I don't see why 26" would be any different).
  15. yonderblue
    yonderblue
    Dec 18, 2001
    302
    Scotland
    +12
  16. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    TX-32LXD500 and TX-26LXD500 same inputs etc as the Plasma cousins both are 1366x768 res panels 800:1 contrast
  17. Hellicopter
    Hellicopter
    Jan 26, 2002
    331
    +5
    Saw them at recent trade show.HD compliant (HDCP) models have '500' in model number.HD LCDs looked impressive.
    Alan
  18. VurtHed
    VurtHed
    Dec 11, 2002
    194
    +6
    Thansk yonderblue! Apologies Hornydragon and anyone I may have confused! :oops: Saw a review saying 'new' and 2+2=5! The ones I mentioned are of course the old new and not the new new.
  19. MilesR
    MilesR
    Nice one guys...I'll be checking those out in July then!
  20. RockySpieler
    RockySpieler
    May 23, 2005
    1,659
    Snaking the Lineup
    +116
    Returning back to the "Direct Digital Link" on iDLCD TV, where the freeview box sends its digital signal directly to the LCD's digital processor, instead of first converting to analogue.
    1) Do any of the new generation of iD LCD TV's have direct digital links, or are they still merely parasitic freeview boxes?
    2) Are we likely to see one, or is the market too small for Big Japanese Makers to develop one for?
    3) Are there any freeview boxes with DVI / HDMI outputs (I have a HTPC, which sorts of achieves this: Freeview card + DVI out)?
