LCD TV Ghosting
Discussion in 'LCD & LED LCD TVs Forum' started by Alzir, Oct 10, 2004.
Tags:
  1. Alzir
    Alzir
    Hi I’ve just bought a Viewsonic N3000w 30” LCD TV and am having problems with ghosting when using the PC. This is a 16ms response time panel so I thought that this wouldn’t be an issue. This is my first TFT and I’m not sure that I have set it up right.
    The picture quality is good, very sharp and bright. The contrast is good and the black is black but as soon as I move a window about I can no longer read the text, it goes blurry. It is most apparent in games where I get vapour trails from fast moving objects. If I spin round in CS Source everything goes really blurry. I can’t seem to find any drivers for this monitor either so that also might have something to do with it. As I said this is my first TFT and I don’t really know what I’m doing when it comes to setting them up, there’s very little in the manual and the 24/7 tec support line in closed on weekends.
    I’m not having much luck finding any good set-up guides drivers utilities or anything remotely helpful as I don’t really know what I’m looking for. Any help would be most appreciated as this is driving me mad.
  2. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    how are u connected to the screen?
    DVI or VGA?
    also that blurring in windows of text while moving it is common
