LCD TV for £800
Discussion in 'LCD & LED LCD TVs Forum' started by gripnrip, Feb 6, 2005.
Tags:
  1. gripnrip
    gripnrip
    Have been told that this is the place to come for advice on LCD tvs... so here i am. :)
    I want to buy a LCD tv for my bedroom and have a budget of £800.
    Can anyone recommend/suggest the best set I can get for this money?
    Want a decent size - 26"/27".
    Will be using an XBox and a Freeview box.
    Thanks in advance,
    --gripnrip
  2. gripnrip
    gripnrip
    anyone?
    :rolleyes:
  3. GrahamC
    GrahamC
    Jul 22, 2001
    2,259
    Morecambe, U.K.
    +67
  4. gripnrip
    gripnrip
    Thanks Graham,
    Will that be compatible with Skys future HD broadcasts?
    In fact what do i need to look for to make and LCD tv is compatible?
    --gripnrip
  5. jimg
    jimg
    Jul 4, 2004
    826
    +58
    You need a DVI input that supports HDCP or a HDMI input to work with SKY Hi-def broadcasts. You will need this as well if you want to connect a HD DVD player in the future.
  6. GrahamC
    GrahamC
    Jul 22, 2001
    2,259
    Morecambe, U.K.
    +67
    There is a review of the Acer Here. and as there is no mention no mention of HDCP at unbeatable I would say only standard tv from sky.
  7. rags
    rags
    Apr 13, 2003
    4,161
    London
    +324
    I am not sure the SKY HD compatibility problem is valid for most bedrooms -
    1. Bedroom TV's are small anyway and a HD picture wont have as much impact as with a big TV.
    2. Re SKY - unless you plan to have the HD Digibox in your bedroom then you will need a bloody long HDMI cable from your living room for it to work. They arent cheap.
    3. Even if the long HDMI cable isnt an issue if the SKY box doesnt have two multiple out then you will need some sort of signal splitter to receive pictures in two or more rooms.
    I can bet there will be other issues involved.
    I thought about it as well and then decided the buy the best TV / price combination I could for my bedroom and sod the Sky compliance.
  8. loz
    loz
    Jun 4, 2001
    13,062
    +1,787
  9. loz
    loz
    Jun 4, 2001
    13,062
    +1,787
    is there a £650 26" LCD that DOES support HDCP?
