LCD tv as monitor for older Apple Macs
Discussion in 'LCD & LED LCD TVs Forum' started by riverrun, Jul 15, 2005.
Tags:
  1. riverrun
    riverrun
    Jul 4, 2004
    37
    Looking for a 17" or so cheap LCD tv for the bedroom that could be used if pushed as a monitor for an old Apple Macintosh (PowerMac 7300 with 604e processor). Any ideas, and is it possible anyway with this machine?
  2. c.jelly
    c.jelly
    Jul 12, 2005
    222
    +3
    Is that one of the Macs with the old big connector? DB15 I think is the port?
    You can get an adapter off eBay for a couple of quid to turn it into a VGA port.
  3. riverrun
    riverrun
    Jul 4, 2004
    37
    Yes I'm using one of those adapters at present to connect a LaCie Electron, I was more concerned about the software/drivers needed.
  4. c.jelly
    c.jelly
    Jul 12, 2005
    222
    +3
    I wouldn't worry, it should just come up as a generic monitor.
    That's what happened when I connected an old Apple CRT (manufactured in 1995) into a new iBook. More than likely works the other way round.
