LCD TV above fire
Discussion in 'LCD & LED LCD TVs Forum' started by Qubit, Sep 16, 2005.
Tags:
  1. Qubit
    Qubit
    Aug 11, 2005
    15
    I recently bought a Samsung 32BDX and the perfect position for it in our living room would be on the fireplace.
    My only concern is the heat. We have a 4kw (max) hole in the wall gas fire and the TV would be sitting approximately 3 foot above this. We only use the fire during the winter and usually only for 2-3 hours per night.
    I've searched the web and the advice seems to be mixed. Some people say that providing the wall temperature, where the TV will be attached, is less then 90F then it should be ok. Others say you should not attach it to the fireplace under any circumstances.
    Any thoughts on this? Would the heat be likely to cause any damage?
    Thanks,
    Q
  2. bledd
    bledd
    Aug 25, 2005
    58
    +5
    Heat would affect the cooling of the tv, if the ambient outside temperature is to high then the unit will over heat, this does not mean that you can't place it above the fire though. If for example you have a mantle piece above the fire which protrudes out of the wall then this will help prevent the rising heat pass behind/in front of the tv.
    Bledd
