LCD tuning...
Discussion in 'LCD & LED LCD TVs' started by MattDX, Jan 28, 2005.
  1. MattDX
    MattDX
    Jan 21, 2005
    3,967
    +257
    I've heard the standard CRT tuning DVDs are no good for tuning an LCD screen. Just got mine and wondered if anyone had any tips???
  2. Judders
    Judders
    Oct 31, 2004
    154
    16
    Basingstoke
    I think it depends on what LCD you have. I have a Sharp 32GA4E and there's plenty of info on the forum and suggested settings. But a lot of people swear by the DVE DVD for LCD calibration (haven't tried it myself). Search this forum for DVE and I'm sure you'll find loads of info.
    HTH.
  3. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    With DVE, the basic test for contrast is inappropriate to LCD - it works by adjusting contrast until a white box edge blooms. With a fixed display such as LCD, this does not work. But alternative test patterns are included, but are not explained so well and are not quite so 'right or wrong'.
    I have no experience of Avia (or Avia pro which would be my preference if it supported PAL), but I have also used an American magazine's setup disc that I cannot remember the name of. Their basic setting for contrast worked fine for the plasma that I was calibrating as they used a different technique.
    -Ian
