LCD TIMER REMOTE CONTROL Shutter Release FOR Nikon D3100
John Muriel
i've got a timer remote for my nikon d3100, it works when i press the button on the remote, but when i try and do like a timelapse, it only presses the shutter down half way, so it doesnt actually take the picture. Please respond, as this is really starting to annoy me now
i have read the instructions and followed it step by step but no joy, It worked the first time i bought it after a few hors of tweaking with it< i can see the light flashing when i start it but it doesn't trigger the shutter
Please help im getting a bit frustrated
shotokan101
Can you post details of which timer-remote you bought ?
Ugg10
I have a very similar one for my Canon, the instruction are in the best chinglish and also it is not that intuitive to work out the delay, shutter duration and number of shots. It took me a couple of goes to get it right.
Did you turn your lens/camera to manual focus once you have set up the shot, this may help.
Not knowing the Nikon, did you set the shutter mode to remote/multiple shots as well ?
If you are after time lapse then you can always set the shutter speed to 30s, expose and lock in the aperture, focus and turn to manual focus, set multiple exposures mode, and then just lock down the shutter release. The camera will click away until you release the shutter lock.
Hope this helps.
John Muriel
i am using a nikon d3100, it has not remote shutter mode but i do have it on single mode and manual mode together with the lens
the shutter release button works but when i try to do timelapse i can see the timer counting down but it doesnt trigger the camera shutter
shotokan101
Does Does the shutter remote trigger the camera in simple remote cable mode ?
John Muriel
yes it does,even without batteries so I am guessing it must be something to do with the settings in both the camera or the shutter remote
shotokan101
see if this helps ?
Jim
John Muriel
I already watched this video a few times but nothing seems to work
I am getting frustrated may be i will just purchase a better one
have you any suggestions for which one to look out for?
thanks a lot btw
John Muriel
they look like the real mcCoy but thy are out of my badget though. i am a photography srtudent cant really afford those
thanks heaps i will keep them in mind for the near future
shotokan101
thanks a lot btw
Odd - does the trigger LED flash after the countdown ?
John Muriel
yes it does, it turns green a few seconds before it is supposed to trigger the shutter
the shutter doesnt release when it is supposed to
driving mad
shotokan101
driving mad
If I do a simple 4 second timed release it flashes green each second and then turns red and triggers the camera - does yours turn red after the countdown ?
shotokan101
...could just be faulty I guess - just because the manual button triggers it doesn't mean that the electronics are connected to the cable....
shotokan101
but if that was the case it wouldnt work when i press the shutter manually
But it could - the physical switch can still short out the connection needed but the electronics might not... you'd need to test with a meter to confirm...
shotokan101
it was working when i first got it i just cant remember what settings i used
what do you mean by test with a meter?
If it was working originally then have you tried disconnecting the batteries to force a reset and test again ?
By test with a meter I meant that you should find that pressing the shutter button on the remote shorts out - or possibly opens the connection - between a couple of pins on the remote connector - so if you used a multimeter to check resistance between the pins as you should see a change when you press the button - then onec you've identified the trigger pins just check again with the countdown...
shotokan101
Great news - hope it all works out :)
Latest News
What's new on Netflix (UK) for October 2022
  • By Ian Collen
  • Published
Starzplay streaming service rebrands as Lionsgate+
  • By Andy Bassett
  • Published
JVC adds Filmmaker Mode to latest D-ILA projector firmware
  • By Andy Bassett
  • Published
Bowers & Wilkins launches Px8 headphone
  • By Andy Bassett
  • Published
Sky set to launch its plug-and-play Sky Stream solution
  • By Ian Collen
  • Published
