LCD/TFT signal input question
Discussion in 'Desktop & Laptop Computers Forum' started by Joe Pineapples, Jan 23, 2004.
  1. Joe Pineapples
    Joe Pineapples
    Oct 23, 2001
    7,336
    Doncaster
    +1,130
    Anyone know if its possible to run a skydigital video signal (via scart), into a PC LCD monitor (maybe via convertor or something)?.
    The LCD screen is a standard one, with a VGA & DVI input at the back.
    cheers
    Dean
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,258
    Manchester
    +753
    Skyboxes output straight RGB.
    PC inputs are either RGBHV (separate syncs) or RGB-S (composite syncs). They are TTL (digital) sync signals.
    Your problem would be to generate these separate sync signals.
    Chris Muriel, Manchester.
