LCD tellies...any good? This looks a bargain?
Discussion in 'LCD & LED LCD TVs Forum' started by brotherbear, Aug 23, 2004.
Tags:
  1. brotherbear
    brotherbear
    I was going to buy a plasma TV but have now started to look at LCD's.
    This one looks pretty good and seems a very good price:
    http://www.richersounds.com/index.php?f=itemdetl.php&p=302308
    I have seen that John Lewis stores sell this same set for £5495 but you get a free 13-inch LCD too:
    http://www.johnlewis.com/Shopping/P...visions&PRT=Televisions&Type=SKU&Id=230198570
    I wonder whether they would match the Richer Sounds price AND include the free set along with 5-yr warranty? What do you think?
    I heard that LCD's do not suffer screen burn like plasmas? True or false? It seems to me that plasma's are not the way forward for TV's and that LCD will be the dominant technology.
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,383
    Somewhere in South Yorkshire
    +5,770
    LCDs do not suffer permanent damage from static images. Some LCDs do suffer from a persistent latent image (very dim, barely perceptible) but this is always temporary and disappears with the next "refresh" of the picture content. I only mention it because there is another forum member who insists that this artefact is screen burn; it isn't. Screen burn is permanent, and occurs only on phosphor-based technologies. LCDs aren't phospor based.
    Somehow, I doubt you'll get JL to match on those terms; price matches are typically for like offers. You can but ask, however.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    You'll probably get warranty if local RS has it in stock.
  4. Tony8377
    Tony8377
    Aug 19, 2004
    954
    Essex
    +4
  5. TheBoingoBandit
    TheBoingoBandit
    Jul 27, 2002
    779
    28
    +26
    It's not screen burn, but when it happens it is VERY noticable and very, very irritating.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    "Residual latent image" i think is the technical term and it can be as bad as screen burn!
  7. LV426
    LV426
    Jul 14, 2000
    13,383
    +5,770
    With respect, it can't be as bad as screen burn. Because screen burn (as applicable to phosphors) is permanent, and can only be corrected by "ageing" the remainder of the screen to the same extent as the area damaged by a static image (eg a logo). Unless and until this is done, it will remain visible depending on image content.
    Whereas, the latent image which some LCDs exhibit fully corrects itself the next time the image contains something different (other than black).
    In other words, the one is permanent, the other is short-lived.
    No comparison.
  8. Hicksy
    Hicksy
    As far as i am aware, as long as you don't continue watching a 'logo'd' channel for more than 2-3 hours at a time, there should be no probs.!
  9. LV426
    LV426
    Jul 14, 2000
    13,383
    +5,770
    At the risk of sounding like a stuck record.....
    With an LCD you can watch a logo'd channel all year, without causing any permanent damage.
  10. Hicksy
    Hicksy
    sorry, typing and speaking on the phone never works!
    I missed the point briefly!! Soz
  11. brotherbear
    brotherbear
    Thanks guys...sounds like LCD is the better choice.
    The more I look at this set, the more I like it. Loads of connectivity options...more than any other set I've seen I reckon. And I'm starting to think that 42 inches is just TOO big for normal viewing. Every 42" I've seen shows up lots of artefacts from digital TV.
    I already have a freeview box (pace twin) but I like the thought of the set having a built in freeview tuner. Coupled with the pace twin I'll be able to watch freeview without the twin being on. Will only need to use it when recording. Even if a TV has freeview built in you still need to buy a seperate freeview box if you want to record one channel whilst watching another. And then you'd need to buy a HDD/DVD recorder and set the timers on both to record whilst you're out. With the pace twin it's easier.
    Also, I notice this set lacks DVI/HDMI. Would I be missing anything without this? Is component progressive scan as good? Would I really notice the difference?
    And I see the resolution of this set is 1366H x 768V. So is it high-definition ready? Is high definition available via the component input? I thought you could only get hi-def via the new DVI/HDMI?
    Be good to know.
  12. Hicksy
    Hicksy
    Good points. If I have Dvi inputs, does that make my display HDTV ready?
    Bit confused and is prob a simple question! :confused:
  13. Rob20
    Rob20
    Jul 3, 2004
    3,100
    +663
    Component cables are able to deliver a hi-def signal. However, screen resolution doesn't neccesarily guarentee that the set will accept hi-def as according to What HCC, Panasonics 32" TX lcd that has a res of 1280 by 768 wouldn't accept a high def signal of 720p, or 1080i. Though I'm sure What Hifi Sound and Vision said it was able to!? Best check before hand.
  14. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    I think it would be able to accept 480p, 720p AND 1080i. The only thing is, if the resolution is higher than that of the panel - in this case 1280x768 (so it sounds like 720p would be possible) - then it will simply be scaled down and you won't see the full benefit of the hi-res format.
  15. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    some DVi sockets are only capable of 576p or 720p in certain displays! but 1080i over component........................ Go Figure!
